Why are my stock exhaust bolts welded on? (see pics)
1/4 in. Air Die Grinder
to mount this:
Cut-off Wheels - 4-1/2" Cut-off Wheels for Metal, Pack of 10
on this:
http://www.harborfreight.com/1-4-qua...nder-93389.htm
It may be a safety concern that the right angle doesn't have a guard.
I had to put a wet rag on my face and used safety glasses due to all the sparks!!
Maybe this will work:
120§ Air Angle Die Grinder
Last edited by m3clubracer; May 19, 2016 at 10:31 AM. Reason: I had to put a wet rag on my face and used safety glasses due to all the sparks!!
I actually used this:
to mount this:
on this:
to mount this:
on this:
Wow thanks for all the tips, those 4.5" cutting discs..how do they attach to the die grinder? I might look into a giant welding helmet, something better than simple safety glasses. THe 120 degree air angle die grider looks solid!! Will stop by harbor freight tonight and scope it out.
Edit: I just googled some pictures of harbor friend grinders to better illustrate the removal and wow, there are some very bad accidents of broken wheels stuck in peoples faces etc... DO NOT google it lol.. Make sure you get some goggles....
NeoNz - I was looking to install my Top Speed Y Back exhaust and also saw that the 2 bolts on the flange on the Y pipe where it meets the mid pipe is also welded on. So it must have came from the factory that way. No idea why they did it that way.. It's going to be a PITA to get out.
New Megan Racing exhaust sounds fanstastic btw. couldn't be happier
