Test Pipes, anyone?
Old Jan 21, 2016 | 03:45 PM
  #31
Chekov's Avatar
Chekov
Senior Citizen
Originally Posted by Scruffmcbuff
Most mods we do to our cars are illegal. Most intakes, most exhausts, have your tires slightly stick outside the width of the car and no mudflaps? Illegal as well. I hate every time the topic of test pipes comes up and someone always has to complain that they're illegal, yet they run HFC, which are illegal too.
I guess I’m one of those who complain that that test pipes are illegal, but I do not run HFC’s either. And it’s not my fault that this topic gets under someone’s skin. I recall that in another forum threads on test pipes were banned. Of course it will never happen here, but I would like to see it.
Old Jan 21, 2016 | 03:48 PM
  #32
demo401's Avatar
demo401
The cyber patrol is too real
Old Jan 21, 2016 | 07:03 PM
  #33
To that end... I was very concerned about getting a CEL with my FI RHFC's. Turned out to be unfounded. Almost two years later, and not a single problem.
However, I will point out a design consideration about FI products that's worth noting. FI doesn't support the connecting bracket that runs from each cat and connects to the underside of the transmission with rubber bushings. Without this bracket, there's a fair amount of noticeable vibration going on. Here's a thread I created last year on the topic. It didn't get much conversation, but there's info there, and pictures:
https://www.myg37.com/forums/g37-sed...tions-hfc.html
Old Jan 21, 2016 | 07:26 PM
  #34
xnick101's Avatar
xnick101
I just had my berks non resonated TP's put in monday. Driving normally, you can't even tell it has TP's. Maybe the car is a bit louder. But if i get on the gas there is a ton of rasp around 2.5k rpm all the way through about 3.5k. But after that it's more just overall loudness. I have had no CEL light, yet... And I don't care about the smell because all my friends have been catless ever since we started to mod our cars. So im used to the global warming smell. Personally, after my experience with my non resonated berks, I would only recommend HFC or something resonated for sure. But I've had people rev my car and do fly-bys while driving my car, the noise is alot worse inside the cabin than out.
Rasp is due to test pipes being unresonated. #1 reason why I have resonated test pipes.
Old Jan 21, 2016 | 09:57 PM
  #35
Scruffmcbuff's Avatar
Scruffmcbuff
Originally Posted by demo401
thats exactly what the previous owner did with my car when he installed all this crap on it. When he went for inspection he put all the stock pipes back on and set it to stock map. Thats what he told me to do when I bought it. NOT in any way am i suggesting u do that
The fact that you bought a modded and tuned car scares me. I say this because I'm in car business and know how these situations turn out. But I wish you goodluck!
Old Jan 21, 2016 | 10:00 PM
  #36
Scruffmcbuff
So you joined a car forum just to throw in your 2 cents? Even though you don't mod your car?
Old Jan 21, 2016 | 11:48 PM
  #37
demo401's Avatar
demo401
na i know the whole history to the car dude put like 8k miles on it and hes the second owner. He bought it to build as a hobby. barely drove it and everything was done at a well known performance shop with documents. I think after he swapped out the stock exhaust to pass ins and swapped it back he didnt want to go through with it again. When i bought it the sticker was expired for months kid put all his $ and in it but never actually enjoyed it. I guess the "modding" was his only enjoyment therefor i bought it and enjoyed it for him
Old Jan 22, 2016 | 10:13 PM
  #38
Scruffmcbuff
As long as he has all the documents and his story checked out then that's good news! Either way man I hope you enjoy it!
Old May 18, 2016 | 12:05 AM
  #39
Rr1982's Avatar
Rr1982
Is anybody running resonated test pipes on an X sedan if so do you need to use the 90-degree elbow or just a non fouler
Old May 20, 2016 | 11:07 AM
  #40
Kris9884's Avatar
Kris9884
Everyone seems to have different outcomes, best bet is to extend it as much as possible so I would get the elbows and if that doesn't work, you can always clear the code and add extenders too.
Old May 20, 2016 | 01:32 PM
  #41
Rr1982's Avatar
Rr1982
Isn't there a distance at which the ecu would read too lean also?
Old May 20, 2016 | 04:21 PM
  #42
Kris9884's Avatar
Kris9884
I'm sure at some point it would start to but I can only assume it would take a huge difference. My reasoning is because it has to be within a certain range at all times, it would read a ton less at idle and even less at idle at higher elevations, no idea on the exacts though. Even THEN, were talking without any cats at all, I can only imagine how lengthy it would have to be to start reading even less than a cat'd exhaust.
Old May 20, 2016 | 05:22 PM
  #43
Rr1982's Avatar
Rr1982
Test Pipes, anyone?
Right but at idle and higher elevations the ECU also read a map sensor crank sensor air water temp sensors and other things. It also reads the O2 sensor along with the other sensors but in a case where it is too far from the exhaust stream in combination with everything else being correct I would be afraid the ECU would compensate and run too rich because it'll read too lean but you're right there is a very narrow area which the afr's are able to be read from a narrow band O2 sensor.
Old May 20, 2016 | 05:35 PM
  #44
Kris9884's Avatar
Kris9884
Yeah, frys my brain trying to think of all the what if's lol.. I'd grab high flow cats and be done. The hp gain from straight pipes to high flow cats are very minimal, not to mention you're saving on your carbon footprint quite a bit more..
Old May 20, 2016 | 05:38 PM
  #45
Rr1982's Avatar
Rr1982
Yeah I was trying to save a couple bucks because I've done so much into the brakes and the exhaust that I ended up buying a test pipes with resonators I probably should have gone with those Kinetix
