Help aftermarket exhaust clearance
I am looking at various aftermarket exhausts but am concerned about clearance due to my driveway. I encounter a high-center situation as it is a steep underground parking entrance. I'm not concerned about canister clearance but more so the mid section clearance. With the stock setup I currently *graze* the y-pipe flanges and the cross brace thing under the mid pipes. Anything lower would obviously be a problem. Will aftermarket sit lower in these areas? I remember seeing somewhere the cross brace is removed for clearance reasons on some exhausts.
Any opinions on aftermarket exhausts with good clearance and possibly retain this cross brace (pic attached for reference)? I don't want to raise the suspension!
NextLevel Performance
the mid pipes are all the exact same height at stock and go above the frame bar/cross brace. The only differences are located around the rear axels, FI and ARK being the lowest.
My ride height from the fender to the ground is 25 1/2 inches and I clear just fine w/ my fast intentions exhaust. That's including a TS-P front
