How to clean R2C air filters?
pop em off, and use some compressed air and shoot from the inside out.
if they are really dirty, soak it in a mild detergent (oxy clean) and then thoroughly dry it before putting it back on.
Didn't have much luck with the air compressor, a leaf blower however works great for blowing out and if washing getting a majority of the water off too. You want to stick it in the inside and blow out. I also found a hair dryer to help speed up the drying process since the media can hold water and appear dry if you just leave it for a day.
I use a shop vac on the outside of the filters to get the dust and particulate out. As I recall, the R2C instructions say that you can use soap and water if they are really dirty, but NOT to use a hot dryer on them because it will shrink the filter material. Again, you can use a shop vac to suck off the excess water then let em dry overnight.
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
