hole in my CAI...
Old Mar 4, 2011 | 07:12 AM
nydealer's Avatar
nydealer
hole in my CAI...
hey guys have a quick question i have a 08 coupe with stillen 3rd gen CAI and it got small holes from rubbing on the second pipes.. (pics up soon) now my check engine light when on and my engine is not that quiet smooth like it was before. could this be due to that? or its something else?
Old Mar 4, 2011 | 08:17 AM
breftayka's Avatar
breftayka
Yeah it is more than likely because of that. Throw some JB Weld on it and let it sit for a bit.
Holes in the intake piping can cause the air sucked in through the filter, escape through the holes.
Really want to see pictures of this as I have the same intake.
Old Mar 4, 2011 | 12:25 PM
nydealer's Avatar
nydealer
Old Mar 4, 2011 | 01:01 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Yeah that sucks you should have padded it with something. Never let metal rub metal
Old Mar 4, 2011 | 01:07 PM
breftayka's Avatar
breftayka
Ohhhh man. That's bad news bears right there. I bought some rubber hose and split it down the middle and put it on those spots... Like I said though JB weld it and then pad it up.
Old Mar 4, 2011 | 02:10 PM
nydealer's Avatar
nydealer
Ok will this affect my engine tho? Thats my main concern Idk how long i had those holes there...
Old Mar 4, 2011 | 02:14 PM
123u's Avatar
123u
Stillen Gen 3 FTMFW......
Old Mar 4, 2011 | 02:18 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
i put some padding on mine to make sure it woulnt rub on anything...you could have sucked in some metal shaving in through the throttle body. i would it it off and blow them out and clean it and seal it
Old Mar 4, 2011 | 08:47 PM
nydealer's Avatar
nydealer
Olz howdy. i would it it off and blow them out and clean it and seal it
Lolz how i do that?
Old Mar 4, 2011 | 10:11 PM
yogregb's Avatar
yogregb
Should have gone with the injen...
Old Mar 4, 2011 | 10:53 PM
da mayor's Avatar
da mayor
home depot sells some padding you can put by the metal there. it's typical of that part rubbing.
Old Mar 4, 2011 | 10:58 PM
LizardBreath's Avatar
LizardBreath
you or whoever installed it should of done a better job. if you installed it you can see that could cause a problem, too late and yes it can affect ur engine
Old Mar 5, 2011 | 01:31 PM
GTLAW's Avatar
GTLAW
Better yet don't by Stillen!
Same thing happen on my 08 350z NISMO.
Old Mar 5, 2011 | 01:34 PM
A_Palaroan's Avatar
A_Palaroan
+1 lol
Old Mar 5, 2011 | 01:46 PM
TomieG's Avatar
TomieG
Damn! Is that install error or do all Stillen Gen 3 intakes rub like that...
