Those with Stillen Gen 3 CAI
Old Dec 17, 2009 | 10:22 PM
PictureMeRolin's Avatar
PictureMeRolin
I just got my G last week and from what I'm reading the Stillen Gen 3 will produce the most gains in performance. My question to those of you that already have it installed is this... How difficult is it to clean the filters? It seems like it would be a PITA.
If you had it to do over again, would you still go with the Gen 3 or different setup with easier to reach filters?
Old Dec 17, 2009 | 11:02 PM
Staples's Avatar
Staples
Depending on where you live and how many miles you put on your car yearly, you could probably get 15 - 20k out of the filters. That's over a year and a half for me, so it really isn't too bad. Plus you don't have to take off the whole bumper to get to them, just the top piece by the throttle cable.
Old Dec 18, 2009 | 02:09 AM
AvosG37's Avatar
AvosG37
so after 15 to 20k, change filters? or clean it?
Old Dec 18, 2009 | 02:23 AM
Team STILLEN's Avatar
Team STILLEN
K&N filters, what's used in the STILLEN Gen 3 intakes actually recommends 50,000 miles between cleaning unless there is an abnormal amount of dust, dirt, etc.
Some prefer less mileage, and it's up to you, but the filters carry a 1,000,000 mile warranty, and we back it as well.
There is never a need to replace the filters, a simple cleaning/recharge kit will do the trick, minimal effort on the filter cleaning, an hour on a Saturday will take care of it, every 2-4 years or so..
Old Dec 18, 2009 | 02:25 AM
VRG37S's Avatar
VRG37S
Well Stated Josh.. Love my Gen 3 intake
Old Dec 18, 2009 | 08:42 AM
PictureMeRolin
So cleaning the filters won't be a big issue. The other concern I had was making the fuel/air mix too lean.
Has anyone had or heard of problems with this? I read a few threads that warned of it, but never read about anyone that actually experienced the problem. It seems as long as you flash the ecu after install you wouldn't have this problem.
Thanks for the input. Im about to pull the trigger and go on an upgrade spree and want to make sure I get my facts straight before I do.
Old Dec 18, 2009 | 08:57 AM
Team STILLEN
There is no issue with leaning out the vehicle, until you get to the full bolt-on including HFCs and headers. We don't recommend installing all of the following without a tuning solution:
- Gen 3 Intakes
- Cat-Back Exhaust System
- High Flow Cats
- Headers
Combination's of either HFCs or Headers are fine, but with all four tuning is recommended.
Old Dec 18, 2009 | 09:07 AM
PictureMeRolin
What if I just go with a cat back exhaust + HFCs? without headers?
Should I also add a Cobb AP to my shopping list?
Old Dec 18, 2009 | 09:23 AM
Team STILLEN
Without headers you're good to go.. makes great power with those bolt-ons.. with the STILLEN cat-back, HFC's and Gen 3's we typically see 40-50whp..
Old Dec 18, 2009 | 09:54 AM
PictureMeRolin
Good stuff! Thanks Josh!
Old Dec 18, 2009 | 12:27 PM
Buckeye G's Avatar
Buckeye G
I just got test pipes put on with a cat back and stillen Gen3 and I was lean after the test pipe install.
Old Dec 18, 2009 | 01:08 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
+1 for all the stuff Josh said...I have had Gen3's on my G from almost the day I picked it up (one of my first mods) and I LOVE them. They are easy (IMHO) to install, easy to clean, and they arent crappy paper filters that fall apart after 5000 miles. They sound and look awesome, as well as giving some great #'s
Old Dec 18, 2009 | 03:25 PM
Staples's Avatar
Staples
Same, I was very lean. I was getting up to 13.4 range at wide open throttle. I made great power after the tune and I'm down to about 12.6 at redline.
Old Dec 19, 2009 | 01:08 AM
PictureMeRolin
Staples, what's your setup? Do you have test pipes too or HFCs?
Old Dec 19, 2009 | 01:10 AM
Staples's Avatar
Staples
FI test pipes
