Intake issues
Old Jan 30, 2009 | 08:07 AM
franknfire's Avatar
franknfire
Intake issues
I just had an ultra longtube cold air intake installed and now my g is running like dirt. , Ideling is all over the place, no throttle response and somehow how it has affected my window to where they go down when the door opens but dont return closed once you shut the door. Any suggestions?
Old Jan 30, 2009 | 08:20 AM
ryanmross's Avatar
ryanmross
Not sure about the intake issue.. but the window issue is because your battery was disconnected..
Here's a topic that discusses it:
https://www.myg37.com/forums/faq-and...alfuntion.html
Old Jan 30, 2009 | 08:37 AM
G37Sam's Avatar
G37Sam
which intake is that? and what do you mean by idling is all over the place?
Old Jan 30, 2009 | 08:41 AM
SOLISIMO's Avatar
SOLISIMO
I would double check to make sure everything is plugged in. I think its just the computer trying to reset itself.
As far as the windows hold both buttons up for 15 seconds while the windows are rolled up and you should be good to go.
If you want to reset the computer your self do a search for reseting computer w/o disconecting the battery.
Old Jan 30, 2009 | 08:58 AM
franknfire's Avatar
franknfire
Window issue resolved thanks. Now the idling issues are what's concerning me. The car will not sit at a constant idle, it goes from about 800-900 rpm to 1200-1300 rpm. Like i said its all over the place.
Old Jan 30, 2009 | 09:36 AM
Kidcane's Avatar
Kidcane
Florida G Club
MAF sensor loose?
edit: just saw you are from Tampa. Wazzup!
Old Jan 30, 2009 | 11:19 AM
franknfire's Avatar
franknfire
both maf were not loose but sealed incorrectly,so they were sucking in air at the connections. hopefully it will resolve the issue.
Old Jan 30, 2009 | 11:52 AM
chasemyaccord's Avatar
chasemyaccord
What kind of intake did you install?
Old Jan 30, 2009 | 12:06 PM
VONYC's Avatar
VONYC
intake ??
Old Jan 30, 2009 | 08:50 PM
franknfire's Avatar
franknfire
i had a local shop fabricate a cold air intake like the stillen ultralong tube.
Old Jan 30, 2009 | 09:11 PM
gan78mao's Avatar
gan78mao
any pics?
Old Jan 31, 2009 | 05:45 AM
G37Sam's Avatar
G37Sam
seriously.. you had something custom done man post some pix up and share.. its all what the forums about, give n take right?
Old Jan 31, 2009 | 06:47 AM
SOLISIMO's Avatar
SOLISIMO
I think that might be your problem right there, are there any leaks anywhere
Old Jan 31, 2009 | 10:59 AM
aliiin's Avatar
aliiin
BMW Defector
maf sensor perhaps? and post pics and sound clips of this custom fabrication...
Old Feb 2, 2009 | 07:44 PM
ucla bruin's Avatar
ucla bruin
Subscribed.
__________________
