Help Volk offset question... HELP!
Old Aug 3, 2011 | 08:01 PM
usrsld's Avatar
usrsld
I'm looking at a used set of Volk wheels...
Would a 19x8.5 +23 19x9.5 +22 set of Volk wheels be overly agressive on a G37? According to an online offset calculator they would be an extra 29mm out from a stock wheel. I DO NOT want to run stretched tires!
Any and all help would be appreciated.
Old Aug 3, 2011 | 08:03 PM
WPPJR30's Avatar
WPPJR30
It depends on your drop. If you are not slammed, you will be fine...
Old Aug 3, 2011 | 08:13 PM
usrsld's Avatar
usrsld
I can assume wheels will be sticking outside of fenders? I'm already running 15mm spacers on stock wheels and it looks almost flush to me.
Does anyone have pictures of a similar setup?
Old Aug 3, 2011 | 08:28 PM
WPPJR30's Avatar
WPPJR30
I am running a very similar set-up, except my wheels are an inch wider. My wheels do not stick out, my tires are not stretched, and I am not running crazy negative camber. Member _ant_ has almost identical sizes on his SSR's to what you wish to run and he is not running stretched tires.
Old Aug 3, 2011 | 08:36 PM
ipitythefoo's Avatar
ipitythefoo
Yes. They should fit fine, especially since it's only a 9.5 inch rear wheel. Beefy tires ftw
Old Aug 3, 2011 | 08:38 PM
WPPJR30's Avatar
WPPJR30
Keep in mind that my wheels are 1" wider in both the front and rear... As long as you don't want the car sitting on the ground, you will be fine.
Old Aug 3, 2011 | 10:25 PM
_ant_'s Avatar
_ant_
im running 19 x 8.5 +22 and 19 x 9.5 +22
and im definitely not running stretched tires lolz
Old Aug 12, 2011 | 09:51 PM
BobOso's Avatar
BobOso
What size tires are you running?
Stevolkz33
May 28, 2016 02:36 AM
ck1109
Oct 15, 2015 11:06 PM
Kojack
Oct 9, 2015 05:53 PM
bobtaz13
Oct 1, 2015 01:39 PM
VIVID
Sep 27, 2015 09:45 AM
