Help Spacer Recommendation non-sport 18s Coupe
Old Jul 6, 2011 | 08:28 PM
kkokko's Avatar
kkokko
I'm thinking about installing my eibach springs and throwing on some spacers till I get my CV1s.
I'm afraid of vibrations and issues associated with spacers though. Does anyone have recommendations of the best size and brand to go with for the 18inch non-sport rims on a G37 coupe?
I know hubcentric 20mm front 25mm back is pretty good for AWD which should be same for non-sport coupe.
But what brand is proven? Ichiba, Eibach,
Old Jul 6, 2011 | 11:00 PM
Weiboy718's Avatar
Weiboy718
H & R
i've installed 2 set's with oem sport wheels and no vibrations at all
Old Jul 7, 2011 | 01:36 AM
GraphiteG37S's Avatar
GraphiteG37S
^ What Wei said.. I've heard good things about H&R spacers.
From first hand experience I have Project Kics spacers with built in studs and they are also very good with no vibrations.
Old Jul 7, 2011 | 08:33 AM
ANMVQ's Avatar
ANMVQ
+3 For HR spacers I have 20 MM all around X Coupe 18's.
Old Jul 7, 2011 | 04:20 PM
Presto's Avatar
Presto
if installed right h & r should have no problems. just use fine sandpaper on the hub and behind the whee,l basically everything the spacer would touch. remove all rust. clean area, use a good torque wrench. you should be vibration free
Old Jul 7, 2011 | 04:33 PM
kkokko's Avatar
kkokko
Will most car performance shop know what to do?
Do I need to tell them what to torque it at etc..
Old Jul 8, 2011 | 12:05 AM
OB G's Avatar
OB G
uhhh putting on spacers is as easy putting on your tires. even easier because you don't have to lift a heavy tire. and i believe it's 80 ft/lbs.
SBG37
Mar 12, 2021 03:16 PM
MJ HINX
Aug 23, 2015 10:30 PM
marquisj
Aug 23, 2015 12:13 PM
abretz89
Aug 20, 2015 11:58 PM
gcruzjr78
Aug 18, 2015 10:15 AM
