Help 2014 q60 pas side replacement
Old Sep 1, 2020 | 04:13 PM
Misterbrisco's Avatar
Misterbrisco
14 q60 coupe axle pas side replacement
Hey, guys I apologize in advance for the annoying post. Just trying to learn and understand this car a bit more. I just recent purchased a 2014 q60 awd, and after about 3 months of driving I started to notice some grease spots in my pas side inner wheel. I immediately assumed it was my axle boot leaking. My tech recommended for me to replace the entire axle instead of trying to fix the boot. I decided to go with z1 oem axle figured it would no problem. After bringing the part to the mechanic he tells me that my axle should have a shaft on both ends. I’ve been trying to exchange it with z1 for 2 weeks now and they won’t budge stating that they sent me the correct part and my car should not have a axle on both ends. My mechanic sent me a pic of what it should look like. I just wanted to get a understanding of the difference in these parts. I want to be safe and go with oem but autozone is the only one I can find with the part available near me since z1 claims they can’t exchange for the same part.
This is the one my mechanic is telling me I need
This is the axle z1 sent for a 2014 q60 awd
Last edited by Misterbrisco; Sep 1, 2020 at 04:22 PM. Reason: Did not include subject
Old Sep 1, 2020 | 05:14 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Z1 sent you the wrong axle. From your picture it seems they sent you the axle for the LEFT/DRIVER side- which has the six (6) bolt flange mount. You need the PASSENGER/RIGHT side axle that has the splined stub mount.
This may help:
Z1 should be able to swap them no problem. Either you ordered the wrong one by error or they sent the wrong one in error. Either way, easy to remedy.
ChinkyChoy
41
Jul 8, 2023 11:13 AM
OldG2NewG
60
Jun 11, 2020 11:43 AM
tscani
Jul 28, 2016 10:51 AM
