Clutch won't come back up
Old Jun 10, 2020 | 02:20 PM
Adbraxx's Avatar
Adbraxx
Hello guys this past week while driving, my clutch won't come back up. it comes and goes as i drive. My fluid is a little dirty but is full I'm going to start by flushing it. Does anyone has the same issue ?
Old Jun 11, 2020 | 02:45 PM
Birdie's Avatar
Birdie
sounds like your CSC is going out
Old Jun 11, 2020 | 03:02 PM
Adbraxx's Avatar
Adbraxx
Thats the worst man I spend all day pimping air out it was endless I just gave up
Old Jun 11, 2020 | 03:03 PM
RMB5190's Avatar
RMB5190
Slave is dying. Common issue with the G37
Old Jun 11, 2020 | 03:40 PM
Get that CSC replaced ASAP. You've got aftermarket options. If you take it to a shop, prepare yourself for a day's labor cost, because the transmission has to drop for access.
Old Jun 11, 2020 | 06:37 PM
Adbraxx's Avatar
Adbraxx
Yeah man I gave up as well I'm just taking it to a shop let's see what happens.
Old Jun 11, 2020 | 06:38 PM
Adbraxx's Avatar
Adbraxx
Yeah man I'm taking it to a shop tomorrow what brand would you recommend and how much does the job cost?
Old Jun 11, 2020 | 06:58 PM
Surfnazi's Avatar
Surfnazi
Oem is fine also change our clutch line for braided ss one
Old Jun 11, 2020 | 07:15 PM
Like I already said, prepare for a full day labor cost. 8 hour job or more at $xxx/hour, plus parts. I had mine replaced under warranty 7 years ago, and it was a $1500 job at the dealership.
Research CSC elimination kit. Z1 sells one, so does ZSpeed.
Whatever you do, upgrade your clutch pedal to the RJM kit. Part of the RJM marketing claims is that it addresses the reason why the OEM CSC fails so often. So there's that, plus the fact that the clutch pedal is a pretty awesome mod.
Old Jun 12, 2020 | 02:11 AM
Birdie's Avatar
Birdie
I would recommend cmak from zspeed.
Old Jun 12, 2020 | 08:53 AM
jpowersjr2's Avatar
jpowersjr2
Get the CMAK from Z Speed.
Old Jun 12, 2020 | 04:54 PM
Adbraxx's Avatar
Adbraxx
Ill look it up. Can I change theithe pedal my self? And I took it to the shop the guy said he'll charge me 800 dollars for labor. But he wants to put oem parts in it and he wants to Change the clutch as well.
Old Jun 12, 2020 | 06:50 PM
SonicVQ's Avatar
SonicVQ
Is the clutch fluid low?
If not, the cause may be an internal leak in the clutch master.
When the slave cylinder leaks, it drips on the ground and the reservoir empties.
I have also read that the RJM pedal is a nice upgrade, but it doesn't prevent/reduce CSC failure according to long time Nissan expert Jim Wolfe:
(source: page 2 of http://jimwolftechnology.com/wolfpdf...NS_2_PAGES.pdf)
Old Jun 12, 2020 | 07:16 PM
An improvement on the OEM design. Nice! I didn't know about the JWT CSC.
As for the claims from RJM, note the second bullet: https://rjmperformance.com/370z-g37/
Feel free to reach out to RJM for an explanation, because I don't know what it is. Used to, but don't anymore.
Old Jun 12, 2020 | 07:25 PM
SonicVQ's Avatar
SonicVQ
If memory serves correct, the RJM pedal reduces the stoke on the CSC to prevent the chance of "over stoke" where it cracks the plastic and leaks.
If you have the money, the best solution just may be the JWT CSC and the RJM
