Water moisture near window speakers
Old Oct 13, 2017 | 12:08 AM
hdk703's Avatar
hdk703
So I've noticed this odd issue happening after I take my car in for a wash. This seems to only happen after it goes through the car wash. After I've gone through, there seems to be a small amount of water that always peaks in through the tweeter speakers near the window. This doesn't seem to be an issue after any sort of rain
Is this something that I should get checked out, does this have something to do with the way the door/windows are insulated?
Thanks for the feedback, wasn't exactly sure where to ask this.
Old Oct 13, 2017 | 05:15 AM
Surfnazi's Avatar
Surfnazi
Make sure rubber flap is going over the triangle tip outside the door near the mirror
Old Oct 14, 2017 | 05:45 PM
hdk703's Avatar
hdk703
It is, but it looks like its coming through the speaker itself
Old Oct 16, 2017 | 03:04 PM
Surfnazi's Avatar
Surfnazi
the housing would be cracked then...make sure you have the weather strip seated correctly...pull it loose and repress it in. People rarely use the interior detailer spary or rejuvenator on the weather stripping keeping it from dry rotting from uv
