Help Exhaust rattle?
Old Jul 14, 2017 | 12:58 AM
Josh Bell's Avatar
Josh Bell
Exhaust rattle?
So I just got a 2008 g37 sport coupe on Monday, loving it so far. The only thing I have noticed is when I'm either parked or just idling there is s rattling sound from near the mufflers. It sounds a little different from the exhaust rattle videos I've seen and goes away when I rev the engine as well. Is this how it starts or could it be something else?
Old Jul 14, 2017 | 02:20 AM
hurleyguys's Avatar
hurleyguys
if it happens at idle. i would just idle the car and take a look down there to see what is happening. it could be an exhaust hanger is loose or maybe a heat shield is loose or hitting something.
Old Jul 16, 2017 | 01:44 PM
Josh Bell's Avatar
Josh Bell
So apparently it's inside the muffler. Washed my car today and a buddy of mine checked it out. Any idea of what it could be?
Old Jul 17, 2017 | 08:17 AM
NealP's Avatar
NealP
Maybe a rock or pebble got in there?
Old Aug 26, 2017 | 08:54 PM
Anon's Avatar
Anon
I have a similar problem with my 2008 G37s and a very knowledgeable Service Rep said it was a loose baffle in the muffler. A new muffler is very expensive so he suggested just living with it.
Old Aug 26, 2017 | 11:20 PM
PNW_IPL's Avatar
PNW_IPL
There's a recall or tsb on 08 mufflers coming apart inside...
Old Aug 28, 2017 | 11:04 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Just about all 2008's had the rattle in the muffler. The baffles were improperly welded and literally just popped apart. There was a TSB regarding this which called for replacing the muffler. For a 10 year old car the best bet is to just:
a) deal with it;
b) replace it with a new OEM for around $700;
c) replace it with a newer/used from eBay for around $200, or;
d) upgrade the exhaust entirely.
Old Aug 28, 2017 | 09:46 PM
Anon's Avatar
Anon
Thank you for the information.
I have been living with it but am wondering if the loose baffles can move, restrict the exhaust flow, and reduce performance.
Old Aug 30, 2017 | 05:09 PM
kroy's Avatar
kroy
I would either buy a used OEM if you want to keep stock. Check for sale section here and also ebay.
Or just get an aftermarket. i don't think you need a full CBE so just get an axelback. If you live in a dry area, just get a topspeed. It's only $300.
Old Nov 9, 2018 | 07:35 PM
AmongU's Avatar
AmongU
Thanks for the post. I'm having the same issues my2008. My mechanic suggested the same.
