Replacing Front Struts 2008 G37S...
I plan on replacing my front struts tomorrow...and was wondering if there are any tips you folks would have on doing this... I see in the manual that I have to remove the mounting bolts on the lower side stabilizer rod...and then remove the mounting bolts on the upper side of the stabilizer rod...then separate the link from the steering knuckle...
Are there any "gotcha's" I need to watch out for doing this?
TIA
MP-In-The-Wind
TIA
MP-In-The-Wind
Only real pain is the lower mounting bolt that's torqued to like 130 ft lbs IIRC. It's easier to break free if you have an open end wrench to put on the back side of the bolt (I think it's a 19mm again, IIRC) Are you getting your new front set loaded w/ springs? If not, then compressing and swapping out the springs to the new shocks is a bit time consuming and you should have an impact driver to torque down the spring compressor that you loan out from Autozone or similar shop. Be sure to grease those bolt threads real well on the spring compressor.
Thanks BLNEWT.... I've got a big breaker bar and a pipe (just in case)... The new set is not loaded with springs...so yeah...I'm going to have some fun compressing/decompressing the springs! 8^0 I will grease the spring compressor!
Thanks,
MP-In-The-Wind
Thanks,
MP-In-The-Wind
