Help Which Transmission Hose PSI Rating
Old Mar 25, 2017 | 04:54 PM
Bravo at's Avatar
Bravo at
installing a transmission cooler and looking for the correct PSI hose rating. I see two choices 200 and 400? FSM doesnt mention ratings on the OEM hoses and I cant read/see any ratings either. Thanks in advance.
Old Mar 26, 2017 | 01:36 AM
crookncastle's Avatar
crookncastle
no automotive transmission pump pressure exceeds 100psi or even come close to that. you are good with either 200 or 400. if you want to know the actual spec of the transmission oil pressure just look up auto trans line pressure in the service manual.
