Help 2013 g37 running hot
Old Jan 20, 2017 | 06:33 PM
Bxllxrd's Avatar
Bxllxrd
My g37 Infiniti journey is running hot , can smell coolant , it goes up and down on thermostat while driving , fans turn on , coolant is fine no leaks . Thermostat has been replaced and still is heating up . Some smoke comes out of exhaust when I start the car up
Old Jan 20, 2017 | 07:14 PM
When you say it's running hot, where is the max point that your temp needle goes? If it's at the halfway point you should be ok, anything over that and it would be a concern. These all aluminum motors run real hot as far as the temperatures in the engine bay. If you smell coolant then chances are pretty good there is a leak somewhere. Since it's a 2013 you should still have warranty left, I'd let the dealer test the cooling system.
Old Jan 21, 2017 | 02:04 AM
crookncastle's Avatar
crookncastle
plus 1, good advice
Old Jan 21, 2017 | 07:49 AM
telcoman's Avatar
telcoman
Plus 2
The dealer is not a big bad wolf.
Wonder why the OP didn't start there with a vehicle still under warranty?
Telcoman
Old Feb 21, 2017 | 04:53 PM
Surfnazi's Avatar
Surfnazi
Do a visual inspection. You'll see residue of coolant is leaking only a few places it can leak from
