g37 overheating while idling
Old Jul 13, 2020 | 10:21 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by 2010G37s sedan
a obstruction!? What’s that?
Dirt and debris can clog the fins of the radiator which would obstruct air flow. Likewise, a air bubble- or, while rare, debris in the coolant- can impede circulation of said coolant through the system.
Have you checked the fans- yes, both of them, to make sure they are cycling ON/OFF and at full speed? If your car is "overheating" both fans should be roaring.
In the old days we would squeeze the radiator hoses (obviously wearing gloves) and rev the engine briefly. If the pressure on the hose changes with engine RPM's then likely the water pump is good. Not sure that method would work on these cars. However, as replacing the water pump is a very intensive job on these engines and will not be a cheap repair bill, I would get a second opinion before going that route.
Old Jan 15, 2021 | 07:30 PM
KH3_6MT's Avatar
KH3_6MT
OIl is clean? making sure its not a headgasket issue. You should get a headgasket tester
Old Aug 16, 2021 | 07:46 PM
Kpmikey808's Avatar
Kpmikey808
Did anyone resolve the overheating on the gauge
Last week in vegas when it was 108
car was idling almost an hour picking up my son & radiator gauge started going up & once I turned off the ac the temp went back down
Put new radiator fluid about 2 years ago & changed the thermostat yesterday
today the temp went up in the car after idling for 30 minutes
I notice the idle is higher waiting & once I turn the ac off for a few minutes it will go back down
mechanic checked & the radiator fans come on at 215 degrees
I do have a small crack in the radiator reservoir - & it leaks a little from there
Old Aug 17, 2021 | 09:34 PM
ILM-NC G37S
The likely issue when a engine runs hot while idling is either due to insufficient air flow over the radiator or insufficient coolant circulation. Being that you replaced the thermostat you are likely good there with exception to potential air in the system.
1) Have you ensured that both fans are running at full speed when the engine runs hot? When hot the fans should be roaring loud. You can run the IPDM/er self-test to verify.
As the engine gets hot, the temperature gauge will start to rise and the engine idle will increase slightly. This is normal as the engine is trying to circulate more coolant/faster.
2) You mention a cracked coolant reservoir. Keep in mind that while coolant can leak out, air can be sucked back into the system. You could have a air bubble somewhere in the system that prevents the coolant from circulating.
Old Aug 21, 2021 | 12:46 AM
Kpmikey808's Avatar
Kpmikey808
thx for the info
just bought a new coolant reservoir & hope that helps keep it pressurized
Radiator fans come on around 215 degrees
I will check the link u left
Old Aug 21, 2021 | 02:38 AM
Kpmikey808's Avatar
Kpmikey808
Old Aug 21, 2021 | 02:40 AM
Kpmikey808's Avatar
Kpmikey808
Originally Posted by Kpmikey808
just replaced today new reservoir- hopefully that is it
it only overheats when idling with ac on more than 20-30 minutes & fans come on a lil delayed
Old Aug 21, 2021 | 10:43 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Replacing the reservoir won't resolve the issue of air present in the cooling system (which can lead to overheating). You need to properly burp the system or evacuate and vacuum fill. I've always used the latter but it involves a compressor and more equipment. Former is a $20-30 kit from lisle.
vacuum fill -
Amazon Amazon
burp funnel (I think this one fits nissans)
Amazon Amazon
Edit: The pic above does not look like a pressurized reservoir.
Old Aug 22, 2021 | 08:44 PM
Kpmikey808's Avatar
Kpmikey808
vacuum fill - https://www.amazon.com/UView-550000-.../dp/B0002SRH5G
burp funnel (I think this one fits nissans) https://www.amazon.com/Lisle-24680-S.../dp/B00A6AS6LY
Mahalos 🤙- I will check each step
the ipdm test the fans came on but not as strong as I saw in video for the ipdm test
Old Aug 29, 2022 | 12:08 PM
LoganB894's Avatar
LoganB894
I have a 2013 g37 with the same problem except when I went to check my coolant level to see if there was a leak I noticed my coolant reservoir was completely full and theres no coolant under the radiator cap, I haven't added coolant so could there be a clog somewhere preventing the coolant from getting to the radiator?
Ricio1991
59
Sep 19, 2025 05:56 PM
drizzy315
Jul 12, 2020 08:12 PM
G37sPhoton
Aug 10, 2019 03:42 AM
tharbemiko
General Tech Questions
Mar 26, 2011 03:36 AM
