Help Squeaking Noise over bumps? Please help before I go crazy
Old Nov 6, 2016 | 09:41 PM
JohnnysG's Avatar
JohnnysG
Exclamation Squeaking Noise over bumps? Please help before I go crazy
Hi all - I've had this squeaking noise that kind of sounds like my car is like sinking like the titanic any time I go over a speed bump. I tried fixing this problem by doing the two following things:
1) Replacing shocks with Koni's all around
2) Greased the sway bar joints
I don't know what else the sound could be coming from. I went under the car this afternoon and snapped a photo of what I think it could possibly be now, but I'm still not sure. I'll try to take a video tomorrow to replicate the issue - but it's driving me absolutely nuts to the point where I've been wanting a new car. If I fix this problem I'm sure my itch will go away as I always loved my car, but this problem is seriously getting to me now.
Here is the photo:
1) Suspect #1
2) Suspect #2
Does anyone have any suggestions because I'm really losing my ****. Also - does anyone have any idea on why my window keeps squeaking whenever it auto closes when I close the door? Any suggestions on that too?
Old Nov 7, 2016 | 09:48 AM
JohnnysG's Avatar
JohnnysG
Please help
Old Nov 7, 2016 | 12:31 PM
rsingerG37's Avatar
rsingerG37
Looks like you have a decent oil leak in picture 1.
Looks like your lower control arm bushing may be bad. I can't really tell from the picture.
Old Nov 7, 2016 | 01:23 PM
JohnnysG's Avatar
JohnnysG
Yes - think I may have to replace the gasket. How can you tell the lower control arm bushing may be bad? Should I take a better picture>
Old Nov 7, 2016 | 06:53 PM
rsingerG37's Avatar
rsingerG37
For your oil leak its likely leaking from the timing cover, and/or maybe the rocker cover gaskets. FYI the timing cover uses RTV to seal.
I believe (don't quote me) that the LCA bushings are liquid filled. Judging by your picture it looks to be leaking.
Old Nov 7, 2016 | 08:28 PM
JohnnysG's Avatar
JohnnysG
Hey - I think you are right. I'm going to have it checked tomorrow. Thanks so much for your help
