Hi guys, I have a '11 g37xS coupe. I just had an oil change about 3 months ago. I don't put many miles on this car, maybe about ~400 miles a month if that. How many times should I be changing my oil?
Search my friend .... and you will find loads of opinions. What I have been doing for many, many years (when mobil1 first came out) is target 3500 miles and don't let it go past 5000. Some will argue you can push synthetic to 7500 miles but I say why? Just because you can doesn't mean you should. IMHO, oil is the life blood of your car.
Following my method, all of my cars (at least 9) I have gotten over 100k miles, older than 10 years and none have burned a drop of oil ..... cheap insurance IMHO.
Sorry, I searched but couldn't find anyone that drove as little as me. Regarding your recommendations, I don't think I will drive 3500 miles in less than 6 months or more. Should I just change my oil twice a year then? I have put on only 600 or so miles since my last oil change but my maintenance reminder went off so I'm not sure what to do.
You're saying I should bring it into the shop and ask them to check for me?
No, you can do a used oil analysis (UOA) where you ship a small sample of your oil in and they test it. It might be worth doing once or twice, but definitely not needed every time you change your oil.
Blackstone Labs is one of the places that can test your oil.
Ah ok thanks. The cost of the test itself is about $30, that's already 1/3 cost of an oil change. I might just go for the whole thing
5500k miles on full synthetic, no need to do every 3750 there has been plenty of analysis done on synthetic oils and still good at that mileage, I use valvoline full synthetic
The point of having it analyzed is to see if it's safe to proceed with extended oil change intervals. You're not going to have the oil analyzed every time.
