Help Sound deaden roof and tighten antenna
Old Oct 3, 2015 | 12:21 AM
flyingnimbus's Avatar
flyingnimbus
Exclamation Sound deaden roof and tighten antenna
I have an 09 sedan. Does the headliner peal down easily? I just need access to the back portion behind the sunroof. I hear some rattling up there.
Please help me.
Thanks!
Old Oct 3, 2015 | 01:15 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Index of /FSM/G37/Sedan/2009
"INT.pdf" should show you the details.
Old Oct 8, 2015 | 01:18 PM
flyingnimbus
Thanks 13_SkylineSedan I appreciate you sharing the manual with me but I'm still having some trouble comprehending.
Old Oct 11, 2015 | 11:20 PM
flyingnimbus
If I pull the back of the headliner down can I pop it right back?
Please and thank you.
Old Oct 12, 2015 | 07:28 PM
ay37's Avatar
ay37
it starts on page 26 of that pdf.
basically you gotta remove all the plastic pieces holding the headliner in place. you can't just bend it back or you will tear/rip it, if you try hard enough. so unsrew the map lights plastic cover, the handles above the front passenger and drivers door, the two hooks above the rear passenger and drivers door that would normally be used to hang clothing, and also the pillars that run across your passenger and drivers side front windshield. once you have those out, the headliner falls down and you can access the roof, the wiring, etc.
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
Dillybar12
Nov 17, 2015 11:53 AM
CasperG37
Oct 21, 2015 01:03 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
JakeG37
Sep 22, 2015 12:54 AM
