Cruise Control Flashing
Old Nov 19, 2014 | 07:21 PM
RadioFlyer's Avatar
RadioFlyer
Just to update this thread - the Nickel worked for a day then the light came back. Then I stacked two nickels under the switch, and it worked for 3 days. It just came back tonight, but it's very intermittent. As in, it came on, and then I reset it by cycling on/off the car, and it didn't come back. I definitely think it's the upper clutch switch. I picked up a new one, but I'm waiting for it to warm up a little bit before I work on the car again. I'll post when I have an update.
Old Dec 11, 2014 | 11:52 AM
teefar's Avatar
teefar
So what happened?
Old Dec 11, 2014 | 10:43 PM
RadioFlyer's Avatar
RadioFlyer
Oh I'm sorry, I guess I updated in another thread about this. Yes, the update is that I ended up adjusting the pedal and upper switch, and it hasn't come back on since. It's been about a month. So my recommendation is to play with the adjustment of the switch. If that doesn't fix it, change out the switch.
Old Jun 12, 2016 | 03:57 PM
Dangarza's Avatar
Dangarza
Yes indeed! Upper clutch switch it is :)
First things first.
2012 infiniti G37S Coupe 6 MT, 55,000 miles. Bought new.
For the past 6 months I have had the intermittent CRUISE SET lights blinking on and off issue, at which time the cruise control functions do not work.
Resets itself by turning the car off and back on, but then at random, it happens again.
Took it to infiniti dealer, no codes were showing dealer guy said it was probably my 4.5 year old OEM battery (Which I had tested and charged, it was OK and car starting like a champ) nonetheless the issue eventually got me fed up and given that it was a 4.5 year old battery, I gave him the benefit of the doubt; so I replaced the OEM battery with new AGM BOSCH battery. (battery fit is perfect BTW).
Well... the problem promptly returned after installing the new battery.
Time to go online and found the solution right on this thread.
Yes, by just wiggling the UPPER CLUTCH PEDAL SWITCH the problem was solved.
For those unfamiliar, there are two "button" type switches in the clutch pedal assembly; one (at the bottom) gets pushed when you fully depress the clutch pedal.
The other one (at the top) gets pushed when the clutch pedal is released and goes up to its resting position. THIS IS THE ONE AT FAULT.
It is basically a loose connection making poor contact intermittently.
I have driven the car, used the cruise control and all of its features and everything is working as intended.
So the the least I could do is post this information to both thank you and hopefully help someone in the future, as this seems to be a not too rare occurence in manual cars.
THANK YOU.
Old Jun 22, 2016 | 08:24 PM
marauders808's Avatar
marauders808
Originally Posted by Dangarza
First things first.
THANK YOU.
I hope what you mentioned about the clutch pedal will help for my issue. Mine tripped today while on the way to work :'(
Old Apr 1, 2017 | 06:47 PM
Sython's Avatar
Sython
I just wanted to bump this thread to potentially help others in the future. I have a 2008 G37S, 72.5k miles, and I'm getting the flashing SET at random intervals. I fortunately caught it and had codes scanned at the auto parts store. The car threw codes P0605 and C1109. P0605 has a TSB indicating an ECM replacement due to the flashing SET. C1109 is a voltage issue and I'm going to be investigating that as I believe this is unrelated.
Regarding P0605 - My car is far beyond the emissions warranty so this could potentially be a costly replacement and I'm going to try the ASCD switch ($45 for an OEM part from my dealer). I'll report back if it fixes it, but reading these responses on this thread makes me feel quite hopeful.
Thanks for making the thread.
Old Oct 15, 2017 | 11:27 AM
Racerprof's Avatar
Racerprof
Did replacing the ASCD switch provide a solution to the problem?
Last edited by Racerprof; Oct 15, 2017 at 11:28 AM. Reason: Forgot punctuation “?”
Old Feb 26, 2019 | 02:33 AM
Bizzenn's Avatar
Bizzenn
Same issue
Originally Posted by VOLK_TE37
Replace your ACSD Cancel switch, guaranteed to fix your problem!
My dealer even replace my ECU but the same issue came back after a few months. I took out the switch and cleaned the inside contact terminals and it went away and hasn't happened since 3 years ago.
Everyone with this problem are all 6MT owners.
SWITCH ASSY-ASCD CANCEL - 370Z (Z34) 2009+ Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
I have a 2014 Q60 7AT. I would assume this is the correct switch for my vehicle as well?
Old Feb 26, 2019 | 02:20 PM
slartibartfast's Avatar
slartibartfast
Look on www.discountinfinitiparts.com
Old Dec 19, 2022 | 11:17 PM
dcluse's Avatar
dcluse
I know this is an old post but just had a similar issue and want to share my fix. ‘12 G37XS
I just did a brake upgrade (Akebono - that’s a separate subject, but so far VERY happy with it) and when I picked the car up it had this same issue with the Set light flashing and I couldn’t engage Cruise. Shop had no idea and promised to remedy it. After a lengthy forum and YouTube search when I got home, I came across a video about the brake switch and how if it isn’t adjusted perfectly, it can trip the Cruise system with this error. Here’s the link:
Basically there was play in the brake pedal because after the brake swap (depress/repress) the pedal had a new default resting place. I had to loosen the nut behind the brake switch and lower the switch to be fully depressed against my brake pedal. This removed play from my pedal and cured my Cruise Set flash error and the systems works again.
All the best
Originally Posted by Maelstrom
Hey all,
I have a 2008 G37S Coupe and the cruise set light will randomly (about 1-2x per week) come on and start flashing.
The dealership has the car right now and hasn't been able to reproduce the issue yet. They said there was one code in the system, but it was an old code. They mentioned it was something with the ECM, but didn't give me the specific code.
I've seen issues on other forums with other Infiniti's, but wondering if any of you G owners have experienced this or know what might be causing the issue?
Thanks!
eljoker
Future Models
19
May 30, 2022 11:48 AM
vamarris
Dec 9, 2018 11:10 AM
timc00k
Feb 15, 2017 09:15 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Landshark
Sep 29, 2015 11:20 PM
