Bought Wrong Oil
Old May 23, 2014 | 05:53 PM
hollywhip's Avatar
hollywhip
Question Bought Wrong Oil
I'm Running Synthetic but accidently bought 10-30W instead of 5-30W is it going to cause any problems?
Old May 23, 2014 | 06:20 PM
Finzel's Avatar
Finzel
I would return it and get the proper oil, a heavier oil "could" cause your engine to run at a higher temp.
Old May 23, 2014 | 06:48 PM
ZOSTER33's Avatar
ZOSTER33
Did you check to see what the owners manual said?
Old May 23, 2014 | 06:54 PM
It will absolutely cause no problems whatsoever. Don't worry about it. Just switch back to 5w-30 next oil change.
Old May 23, 2014 | 07:07 PM
guy from norcal's Avatar
guy from norcal
yep what Black Betty said
Old May 23, 2014 | 08:09 PM
Adam West's Avatar
Adam West
Yea I wouldn't sweat it. Remember multiple weight oils like 5w30/10w30 are rated for both cold and hot temps. So the 10 designates the viscosity of the oil at cold start temps vs. the 30 which is viscosity of the oil at 100deg C.
If you're changing it out before the winter you shouldn't have any issues with the cold starts.
Old May 24, 2014 | 12:15 AM
financeman's Avatar
financeman
The slightly heavier viscosity oil will not be a problem unless you were to experience very cold weather...something that probably won't happen anytime soon at your location.
Old May 24, 2014 | 04:13 PM
PongSanity's Avatar
PongSanity
Just change the oil. .. call it a loss. .. I bought non synthetic oil 5w30 changed my oil the next day to synthetic
Old May 27, 2014 | 12:11 PM
botlfed98's Avatar
botlfed98
did you just buy it or is it already in your car? I would simply exchange it if you haven't put it in yet.
Old May 27, 2014 | 12:48 PM
inyquest's Avatar
inyquest
So I ran through the manual and it just has the weight listed.
So is it okay to use synthetic?
and if so
Does it still need to be changed at 3500mil?
Old May 27, 2014 | 01:31 PM
rks's Avatar
rks
and if so
while it depends on oil, filter, and driving habits; I don't think even conventional oil needs to be changed 3500 let alone synthetic. you can always find more info in the Oil subsection or look at Bob is the Oil Guy forums.
Old May 27, 2014 | 02:02 PM
inyquest's Avatar
inyquest
Bob Is The Oil Guy | The Internet's Number One Motor Oil Site
Old May 28, 2014 | 11:07 AM
botlfed98's Avatar
botlfed98
I run synthetic and only change it twice a year, once in the spring and once in the fall...
Old May 28, 2014 | 07:59 PM
inyquest's Avatar
inyquest
What brand and weight do you use and how many miles do you thing you run in between changes?
Old May 29, 2014 | 12:15 PM
ExoDus3252's Avatar
ExoDus3252
3500 mile change is a myth for most applications. Unless you track your car hard, or beat on her constantly, with a full synthetic you can routinely go 5000-7500 pretty easily. I'm going to run Redline full synthetic with my next oil change, and since I don't drive my G too hard, I'll go at least 6k.
