Brake light/TPS light/VRC OFF/SLIP always on?
Old Feb 16, 2014 | 09:09 PM
Used2BaHEMI's Avatar
Used2BaHEMI
After accelerating hard or driving for an extended period of time the Break light will come on for 3-5 seconds, then the TPS, VRC OFF, and SLIP lights will come on and stay on until the vehicle is turned off and started again. Has anyone else experienced this issue and what was the solution?
Old Feb 16, 2014 | 10:51 PM
NJ Torque's Avatar
NJ Torque
Inspect your brake fluid level... if low, inspect brake pads...
Old Feb 17, 2014 | 05:22 PM
SPN27RU's Avatar
SPN27RU
+ ABLS switch!
Old Feb 17, 2014 | 05:40 PM
xtremeroller's Avatar
xtremeroller
I had the same issue with mine a few weeks ago, all she needed was new brake pads front and rear. Just look at your brake fluid reservoir, if it is low you probably need new pads. Don't add fluid, replace the pads.
Old Feb 17, 2014 | 07:25 PM
Racindaddy's Avatar
Racindaddy
Same thing happened to my wife's G35. You need brake pads. You can add brake fluid to the reservoir to buy you a little time, but that's just a bandaid.
Old Feb 17, 2014 | 07:26 PM
G Rated's Avatar
G Rated
Your fluid level is low. But agree with xtremeroller, when you change out your pads, that will press your fluid level back where it should be. You could top it off to get rid of the light from coming on, but you'll have to remove some fluid when changing your pads. I know all of this because I did exactly that.
Old Feb 19, 2014 | 09:24 PM
Used2BaHEMI
Thanks Gents, fluid is low so I will be replacing pads this weekend. If problem persists I will let y'all know.
Old Feb 19, 2014 | 11:43 PM
Gville37's Avatar
Gville37
all the above are correct. same thing happened to me. all good now.
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
