bubbles in oil
Old Jan 25, 2012 | 08:02 PM
08g37's Avatar
08g37
bubbles in oil
so today i wanted to check my oil and as i took the dipstick out to look the oil had bubbles on it. is this normal? something i should be worried about? i even put it back in and out 4 or 5 times and each and everytime it had bubbles iv never seen this in any of my car before.
Old Jan 25, 2012 | 08:15 PM
eksigned's Avatar
eksigned
that's actually a very good question, because i have the same issue. i've always been informed that bubbles in your oil = a bad thing. but my car doesn't seem to have any adverse effects from it. dyno doesn't show anything (i suppose it wouldn't anyways) in terms of power loss, and the car seems to be running strong...? hm...
subscribed.
Old Jan 25, 2012 | 08:27 PM
Mike's Avatar
Mike
is it just a few bubbles or froth?
Old Jan 25, 2012 | 09:09 PM
MyocyteX's Avatar
MyocyteX
I have this as well, but I don't think it is a problem. Not sure, but it just seems to happen as a result of pulling the dip stick up.
Old Jan 25, 2012 | 09:31 PM
1NEETO's Avatar
1NEETO
This is pretty much normal if you're checking the oil shortly after shutting the engine off. It is best to check the oil with a cold engine (let the engine cool down for at least 10 minutes, an hour gives you the best readings) so you can get the most accurate reading. If the oil looks milky then it's time to worry. But some bubbles is normal.
Old Jan 25, 2012 | 10:11 PM
xtremeroller's Avatar
xtremeroller
I also have a few tiny bubbles in my oil when I check it. Wasn't water or any type of contaminate, so I just assumed it was how these motors were.
Coprolite's Avatar
Coprolite
If you are overfilled, it could froth without being milky. What level is it at?
Old Jan 25, 2012 | 10:40 PM
08g37's Avatar
08g37
its above the 2nd dot, im not sure what you mean if its milky?
Old Jan 25, 2012 | 11:09 PM
1NEETO's Avatar
1NEETO
Yeah if it's full on frothing then that's because it overfilled. Best time to check your oil is after te car sits overnight. Milky oil is water mixing with oil which usually means a blown head gasket. It literally look like chocolate milk.
Old Jan 27, 2012 | 02:45 PM
Mayu's Avatar
Mayu
1NEETO is right you have too much oil. The second dot is the MAX point, not to be mistaken with FULL. If you go over this dot the oil could be in contact with the crankshaft and is essentially getting beaten like scrambling and egg - hence the bubbles or froth you are seeing. This is NOT GOOD!! Remove some oil immediately as the oil is not lubricating the engine components in this state.
Victory
17
Oct 27, 2022 03:45 PM
fuzzed
Aug 21, 2020 09:35 AM
Stevolkz33
May 28, 2016 02:36 AM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Chappedj
Sep 28, 2015 03:20 PM
