Help stripped nut on strut tower
Old Apr 3, 2011 | 09:15 PM
Weiboy718's Avatar
Weiboy718
Originally Posted by bat6wc
the stud does not spin. ive tried vice grips but the location of the nut makes it difficult to get to. I managed to get a set of vice grips on there but because of the proximity of the strut bar, its difficult to turn and get leverage.
11mm don't work then use a 10mm with a extension and hammer it in. it cannot be all that tight. be sure to use 12pt socket on it.
Old Apr 3, 2011 | 10:45 PM
Screw using sockets. That often just rounds it off more and makes it worse Use the tool specifically designed for that job, the damaged nut remover. As you turn it, it actually cuts into the nut to tighten the grip and give you more torque. The smaller sized socket method doesn't usually work very well and is difficult.
Old Apr 3, 2011 | 11:04 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
nut splitter? lifesaver for me once.
Upscale Speed
Dec 24, 2015 12:00 PM
*ICE*
Oct 5, 2015 03:05 PM
si_driver
Sep 30, 2015 11:46 AM
BurtoN86
Sep 30, 2015 03:32 AM
dedmanchan
Sep 24, 2015 11:25 PM
