H&R V1 vs V2 Spacers
Old Mar 11, 2011 | 11:51 AM
JohnnysG's Avatar
JohnnysG
Originally Posted by EnviedG35
Vibrations are common with any bolt on spacer. Ive never had any vibrations at all from the ichibas.
Yea, when I was taking off the lugs on the V2 spacers, some were loose and some were tight which I think were the causes of the vibrations.
Old Mar 11, 2011 | 06:39 PM
htran16's Avatar
htran16
sounds scary.....
Old Mar 11, 2011 | 07:07 PM
AroundTheG37's Avatar
AroundTheG37
Woah, the v2's aren't good? Were they torqued down correctly? I was going to install some this weekend but now I'm a little nervous? Were you using stock wheels JohnnysG?
Old Mar 11, 2011 | 07:34 PM
JohnnysG's Avatar
JohnnysG
Nope, I was using Volk GT-30 Phantoms. I had two places torque them down actually, one guy torqued it at 120pb/ft and I went to a dealer yesterday and the guy took them off and re-torqued them down to 100lb/ft and when I took them off myself, I noticed 3 were torqued pretty good, and two of them were loose. So... I really don't know. I'm going to try out these V1 H&R 15mm spacers tomorrow and see how they go.
I heard H&R's were the best, (I'm assuming both the V1's and the V2's are identical in performance.)
The spacers I was using were Ichiba's which many people I read have problems with.
Old Mar 11, 2011 | 07:52 PM
Felix_the_Cat's Avatar
Felix_the_Cat
Well they should have been torqued to only about 80-85 ft lbs which is factory spec for your wheels. Ichiba v2s are known to have vibrations a lot of people said that using a copper crush ring under the hub centric ring fixed their vibrations. I have h&r drm's which are the bolt on style and are torqued to spec with no issues or vibrations. With any bolt on spacer I'd recommend to check them every few months though
