First oil change
Old Feb 17, 2011 | 12:39 PM
xxryanlamboxx's Avatar
xxryanlamboxx
Thanks guys.
Old Feb 17, 2011 | 10:01 PM
Chris11LE's Avatar
Chris11LE
Originally Posted by Steveo47
^^ theres a huge oil filter thread on how crappy oem nissan ones are, i use K&N because of easy of use (they are as good the purolatorONE's which i hear are the best out there) because of the welded nut on the top. PureONE, mobil 1, K&N are all the same filter with a different name, get K&N, i hate oil filter wrenchs are the nut makes life so easy
*TECHNICALLY* you are supposed to be able to take your filter off by hand. Always drive the car to warm it up, and with a little elbow grease, if you put it on correctly during the previous oil change, you should be able to get it off by hand.
I have an oil filter wrench and have never needed to use it except if the vehicle wasnt warm enough, and the last and final time I ever had the dealer do an oil change on the wifes car.....broke an oil filter wrench, had to restort to the "stab it with a screwdriver" trick, it was on that tight
I buy PureOne filters only. Amazon usually has a decent price on the 2 packs so I stock up. Advance Auto has also been having decent prices when combined with one of their many coupon codes. I was able to get the price of a PureOne down to 3.00 or so.
Old Feb 17, 2011 | 10:11 PM
Steveo47's Avatar
Steveo47
^^ im no oil change expert, since this has been the first car ive done the oil changes myself. The manual does say to "tighten as fast as you can by hand, then turn 2/3 of a turn with an oil filter wrench"
Old Feb 17, 2011 | 10:31 PM
Chris11LE's Avatar
Chris11LE
Ive always tightened them by hand. Use one hand to get it snug, then grab with both hands and turn it an extra 3/4 to 1 turn.
Never had one loosen up, never had one not be able to come off. If you put some fresh motor oil on the filter gasket before installing the new filter, it helps with getting it tighter as the gasket wont grab as you are tightening the filter.
Someday it would be interesting to try using a torque wrench with either a K&N filter (with the nut on the end) or one of those slip-on cap-type filter wrenches, to determine just how much torque is necessary during that extra 2/3 of a turn. Once you can put a number on it you can repeat it, and also test to see if you can get close doing it by hand.
Old Feb 18, 2011 | 08:47 AM
KLB's Avatar
KLB
My manual says "Screw in the oil filter clockwise until a
slight resistance is felt, then tighten additionally
more than 2/3 turn."
Old Feb 18, 2011 | 09:12 AM
ualdep's Avatar
ualdep
I agree with using Pure One & Mobil one EP oil filters. Both excellent.
Also, based on my oil analysis ( in A Toyotas & BMW) , most name brand 100% syn oils can do 10-12K for OCI's; after that the TAN (acid) levels start rising too fast.
And for new cars, change UR oil before 3750, say 2K-3K to get rid of the wear metals & Silicon (dirt from casting or sealants).
09 G37S 9K
Old Feb 20, 2011 | 12:19 AM
MACS's Avatar
MACS
If you change your oil yourself... where do you do it? It was easy with a PU... I could fit under it and reach the oil filter and drain plug.
I ain't a fatty (200 lbs) but I can NOT fit under the G.
Do you use ramps? Or do you go somewhere with a lift? What?
I took my 04 G35 to the dealer. I think I want to change my own with the 11 G37 and use Pure one and Mobil 1 full synthetic. (Which I can get on the cheap at Costco!)
Old Feb 20, 2011 | 12:25 AM
CDONNS's Avatar
CDONNS
I'm going to post a DIY on changing the oil here in the next couple hours. Changed mine today and recorded it, keep an eye out.
Old Feb 20, 2011 | 12:26 PM
MACS's Avatar
MACS
Anyone ever heard of Royal Purple?
Royal Purple Consumer Products
Old Feb 20, 2011 | 05:12 PM
tharbemiko's Avatar
tharbemiko
Yeah royal purple is really good synthetic oil. I use it in my other car but it's really costly...about 8.50 a quart here.
Old Feb 20, 2011 | 05:56 PM
Steveo47's Avatar
Steveo47
^^ I dont trust royal purple with all those dyes to make it purple. I'm a motul guy
Old Feb 20, 2011 | 06:37 PM
MACS's Avatar
MACS
I've been doing a little "online research" and I am finding pretty much all positive things to say about the royal purple on all the other forums (Lexus, Audi, Mustang).
I already used it today, anyway...
Old Mar 24, 2011 | 01:50 PM
weaver's Avatar
weaver
I use Mobil oil filter and clean 5000 mobil oil on my altima and was going to do the same on the G, but I would prefer to use Synthetic, since I change my own oil. I may have to try the K&N filter, cause the Mobil is a pain to get off, even by me doing the oil changes and tightening them myself.
If I go with synthetic, I am sticking with Mobil.
Old Mar 24, 2011 | 02:42 PM
  #29
ANMVQ's Avatar
ANMVQ
Man some of you wait a long time for the first EH? I do mine at 750 miles, Will be do it this weekend. Then I do every 2500-3000 miles max an use synthetic Moble 1 Or Castrol..
Old Mar 25, 2011 | 09:05 AM
  #30
KLB's Avatar
KLB
You like spending money on oil?
