Window keeps rolling down?!
Old Nov 2, 2010 | 11:36 PM
teekaywhy's Avatar
teekaywhy
I've had my G for just over a year now. A funny thing started the other week.
When i get home, park, and turn the ignition off, the window on the driver side rolls down half way on its own. any one else have this happen?
I've looked through the manual and can't find anything about it.
HElp!
Old Nov 3, 2010 | 12:05 AM
jnguyen's Avatar
jnguyen
Try to do a window reset.
1.Push and Roll down the windows(hold it)
2.Pull and roll up the windows(hold it for 15 seconds in the up position even after window closes. Doesn't hurt if you hold it to long)
Old Nov 5, 2010 | 01:11 PM
Heat's Avatar
Heat
Also, check your battery terminals to make sure they are on tight. Your windows typically will do this if your battery has been disconnected or died.
Old Nov 5, 2010 | 02:14 PM
teedough's Avatar
teedough
i got the window motor replaced cause it was weak. free under warranty
Old Nov 5, 2010 | 02:31 PM
Punator's Avatar
Punator
Hold both of them up for 5 seconds I believe then turn off
Old Nov 8, 2010 | 07:14 AM
Hayabusa02's Avatar
Hayabusa02
Might sound funny,. but I had a similar problem one day. Kept going out and finding my windows down. Turns out my kids had my spare key and it ended up in the couch. When someone sat down it held the button down to cause the windows to go down. I only thought of this with my car because my grandfather had this happen with his car every time he sat down and his keys were in his pocket. LOL
Old Nov 8, 2010 | 09:58 PM
nolanmann's Avatar
nolanmann
i took of negative and stared having this problem hope i figure it before it rains
just figured it out took a few mins go thru window test a few times you will here motors initiate after several sec then set back to factory settings
cellwoot
Sep 7, 2018 07:10 PM
Kojack
Oct 9, 2015 05:53 PM
RexHavoc
Oct 2, 2015 11:47 AM
CiViCKiDD
Sep 24, 2015 10:47 AM
Wreckreation
Sep 21, 2015 06:27 PM
