G37 Won't start
Old Oct 23, 2009 | 02:54 PM
LuckyLuke's Avatar
LuckyLuke
G37 Won't start
My 08 G is not starting up anymore. After installing new intake. I went for an hour drive. Parked the car overnight. Moved the car out to wash, when I tried to move the car back in the garage. It won't start. Dashboard light lit up, when I tried to roll up the windows. The light went on and off. Is it the battery dead?
Old Oct 23, 2009 | 03:01 PM
SOLISIMO's Avatar
SOLISIMO
unplug the battery then try it again
Old Oct 23, 2009 | 03:49 PM
LuckyLuke's Avatar
LuckyLuke
did that..
unplugged the negative wire.. and the samething..
Old Oct 23, 2009 | 03:56 PM
Blackjack's Avatar
Blackjack
put your OEM intake on and call the dealer.
Old Oct 23, 2009 | 04:16 PM
aznutx's Avatar
aznutx
was the car running while u were washing ur car? otherwise i agree with bj
another thing could just be battery issue, try jump starting, if not then go with the bj's advice
Old Oct 23, 2009 | 04:19 PM
LuckyLuke's Avatar
LuckyLuke
after installing
I installed intake last night. After finished the installation, I did take the G for an hour ride. With no problem. No warning light or anything. This morning decided to wash the car. Moved the car out finished washing it. Tried to move the car back in.. then it won't start..
Old Oct 23, 2009 | 04:36 PM
Wezbian's Avatar
Wezbian
Does it make a "click" sound when u press the starter? I do agree with bj on putting stock back on and taking to the dealer.... shhhh, we wont tell anyone...
Old Oct 23, 2009 | 04:45 PM
LuckyLuke's Avatar
LuckyLuke
removing
I don't know about the clicking.. the brake pedal is really hard to step down too...
Should I removed everything? I got ground wire kit installed couple of months ago...
Old Oct 23, 2009 | 05:43 PM
Loi's Avatar
Loi
can you please try jumpstarting the battery?
Old Oct 23, 2009 | 06:27 PM
LuckyLuke's Avatar
LuckyLuke
jumpstart...
I got one of those battery charge. I charged and it started up. I went for a drive. Everything seem fine, but when I set the alarm for the car. It doesn't honk anymore. Instead it flashed the red car icon with the key.. and right signal light?
Does that mean I need to reset the ECU? when I installed the intake. I did unhook the negative wire for over 2 hours. after that I went for an hour drive.
Old Oct 23, 2009 | 06:35 PM
Loi's Avatar
Loi
I believe there's a setting on the nav. screen that let you set your alarm, to honk and blink lights, or just blink lights. your setting probably resetted to default when you unplugged the battery.
Old Oct 23, 2009 | 07:29 PM
LuckyLuke's Avatar
LuckyLuke
should I?
Should I removed the mods and bring to the dealer to check the battery?
Old Oct 23, 2009 | 07:36 PM
Loi's Avatar
Loi
how old is your car? My battery has died out on me 3 times this week. sucker! time for a new battery.
Old Oct 23, 2009 | 09:21 PM
LuckyLuke's Avatar
LuckyLuke
just
Just 1 yr and 2 months.
Old Oct 23, 2009 | 11:15 PM
LuckyLuke's Avatar
LuckyLuke
Windows
My windows are keep rolling down by itself..
