Vdc, Slip Light And Abs Light Stay On
Okay i have seen this a couple of times. I get in my car start it up press the VDC off button, start driving and some where a long drive the VDC OFF, SLIP and ABS light stay on, the VDC will not toggle. The car operates normally, and the lights go off after a restart. The last time this happened I parked my car and came back, the battery was dead, the car wasn't parked more than an hour. I took the car to the dealer, once before my battery died about the same problem, nothing could be found or messages in the computer. I just brought it back yesterday for service since the battery died and road side assistance had to come. They said it was because of a low voltage indication in the computer... now I hate dealing with service people or any one from dealer ships in general, but the the reason they saw a low voltage indication was found this time is because my ******* battery was dead! They ended up not doing anything........ anyone else see this problem? any recommendations?
Try an ECU reset, this should do it.
https://www.myg37.com/forums/d-i-y-installations-modifications/175792-easy-way-to-reset-ecu-without-battery-disconnect.html
Upscale Speed
Oct 9, 2015 01:42 PM
inspector94
Sep 8, 2015 12:57 PM
