Introducing: Swamp Car - 2013 G37xS
Old May 7, 2025 | 10:45 PM
XhaZm's Avatar
XhaZm
Smile Introducing: Swamp Car - 2013 G37xS
Hey guys.. I'm new to the forums, first time Infiniti owner - long time neglected car lover..
My newly acquired 2013 G37xS, mileage unknown but last odometer reading was 291,000 in August of 2024 according to the CarFax. Shop put a new used motor in it at 285,000. Paid $1,200 for it. It has been a while since I have taken on an aging and neglected budget-friendly pseudo-sports car with over a quarter million on it, but here - I'm willing to do it again....For better or worse.
How I found her: A customer's back lot.
I did find the fourth matching wheel in the trunk
This went up for auction as a repo and my customer bought it. It had no ECU, BCM, AWD module. He installed them, programmed keys etc and it would run for a half a second and die - when it actually cranked over. It wouldn't always.
He didn't care to mess with it further and I made an offer.
It's sat since October 2024 - so about 6-7 months. There was gallons of water under the carpet, all 4 corners. Windshield cowl was off and draining rain right into the cabin air filter all year. I'm no stranger to this problem, setup the 7 gallons/day dehumidifier, ozone generator, steam cleaned interior, shop vac etc - all the typical stuff. Dry as a bone after 4 days and a few steam cleanings. Smells like a normal car again, not bad.
Front passenger fresh water source
As soon as I got it home, I found it had a hidden swamp in it. Wiper cowl was left removed and rain went down the windshield and right into the cabin air filter.
But it won't start. It runs for half a second and dies - but ONLY if the Can Low wire at BCM is clipped (Previous owner's troubleshooting, thanks for the tip buddy). And the information display in the cluster doesn't show anything but a backlight. Gauges and lights work.
When Can L is out of circuit, full comm with ECU, BCM - perform NATS reset etc. Cluster, heater, radio, headlights, starter - it all works. It just dies after half a second, I am assuming because module downstream from this clipped wire is needed.
When Can L at BCM is connected:
• No communication at OBD port
• Electronic fan, climate control & headlights run constantly when IGN ON
• Ignition cannot be turned off
• No crank
Can L Wire at BCM has continuity to ground.. Found the culprit is on the M1 harness at junction box (Combination Meter or the AC Amp)
Well, what is going on.. After doing some of the testing in the FSM for LAN, I found this Canbus L wire has continuity to ground somewhere.
I removed and inspected ECU, IPDM, BCM, AWD module, driver side fuse box/junction block. I unplugged every accessible harness. Tested the modules for resistance.
In the end I found the short to ground was the circuit in the driver junction block/fuse box which powers the instrument cluster. I found pin for injector #6 on ECU was rusted and missing, but it is not jammed in my current harness. Driver junction block is corroded. I disassembled it and it is full of dozens and dozens of pieces of metal traces which are circuit paths, all stacked and separated by a few plastic plates to keep them from touching. I think that one is the culprit. I bought another ECU & junction block, waiting to receive. We will see if it's JB or the M1 circuit on the JB. Disconnected it and cluster/push button stopped working. I am not sure if it powers the cluster directly or just the AC Meter.
FSM does not list the pins on harness M1. It is labeled as "WIRE PASS THROUGH" with no pin identification. That hung me up quite a few times. Pin outs on many harnesses and all modules are listed, but if the harness is labeled as a pass-thru... No dice. I was able to map out which modules use harness M1 on the JB by comparing/contrasting pages, but I did that on paper with hard copy.. Can't paste it here.
OFFENDING HARNESS
Anyway - There is very little rust. Front end looks tight. Steering rack leaks. Oil was good, good coolant. No leaks anywhere to mention other than the steering rack.
Previous owner unplugged the trunk popper and unclipped the emergency pull cord. I had to use a shovel through the rear seat to get the trunk open.
I am hoping I can actually get it started so I can shake down this mess.
I want to know how the trans fluid looks and how much metal in the mesh filter.
I'd like to know compression and see if the motor uses much oil.
I want to know if the AC still works!
It's covered in moss - Sitting since October 2024. I couldn't resist a quick cut and polish on one side while waiting on parts. There are some long deep scratches to tend to
In the half second it ran, I didn't hear any knocks... Which just means there's no rod knock - but it sure could be knocking anywhere else. We'll see!
Anyway, thanks for reading my rambling. I'll get my parts on Saturday and we'll see what happens.
Ran a 7 gallons per day dehumidifier in it for a week, with a few ozone treatments (3hrs total). Clean and dry in it.
Ran a 7 gallons per day dehumidifier in it for a week, with a few ozone treatments (3hrs total). Steam cleaned. Shop vac'd. Basically, everything you expect to make it smell OK again. And it works! There's some things you can't recover, but if mold just starts you can usually get the smell out.. once it starts eating the foam and substrate, it's a goner. Decomposing is the nasty part.
Interior is in OK condition. I do have all plastics. All electronics work. Ripped apart driver seat and less than maintained, but at 300K I think it held up fine
Sold at auction with no computers behind glove box - AWD module, ECU, BCM, etc. My customer put in those modules, programmed keys - it didn't start... so I happen to see it listed and made an offer!
Sold at auction with no computers behind glove box - AWD module, ECU, BCM, etc. My customer put in those modules, programmed keys - it didn't start... so I happen to see my customer listed for sale and made an offer!
When Can-L disconnected, ignition turns on and it all seems to work, except for the info display
When Can-L disconnected, ignition turns on and it all seems to work, except for the info display. No idea what the mileage is yet! My Autel could not display that...
Jf029
Apr 21, 2026 06:36 PM
treyblanford
Feb 2, 2025 09:11 PM
treyblanford
Nov 28, 2024 08:01 PM
TheBradIsMAd
Feb 19, 2024 02:47 PM
M.DomagalskiG37
Jan 1, 2024 02:50 PM
