Code P0301 - Head Gasket Failure?
Old Mar 1, 2025 | 01:49 PM
The Wolff's Avatar
The Wolff
I have a 2011 G37x with 117k miles and the Service Engine Soon light came on when driving to work this week. I brought it to my mechanic and he said it showed P0301 Cylinder One Misfire. He also had the following comments:
Removed sparkplug and noted plug was fouled and smelled of coolant. Put borescope in cylinder one when pressure testing the cooling system and could watch a stream of coolant starting to leak down into cylinder one piston. Suspect head gasket failure.
He referred me to the dealership. I spoke with the service writer at the dealership and was told they don't usually see head gaskets get replaced and that it's usually a different issue. Has anyone run into this with their G37X?
Old Mar 2, 2025 | 04:06 AM
mummy2's Avatar
mummy2
Don't know but most people aren't taking a car that old to the dealer to get a issue like that looked at out of warranty. So the service guy probably doesn't see that issue there that often.
Old Mar 2, 2025 | 09:39 AM
Rik R.'s Avatar
Rik R.
Pretty clear diagnosis... there's only one place the coolant can come from. I don't think you'll get a different answer.
Good luck,
Rick
Spee
General Tech Questions
Dec 31, 2021 08:49 AM
G333
Mar 9, 2018 01:29 PM
Bossman
Nov 6, 2017 03:25 PM
EG Ryan
24
Jan 7, 2017 04:47 AM
Zenzae
Jun 17, 2016 12:50 PM
