Reverse Taillight Modification
Old Jul 28, 2024 | 11:34 AM
UncleLui's Avatar
UncleLui
So I’m trying to run halos on my sedan taillights and was planning on painting the housing black as well. I know how to access the main component of the headlight through cutting, but does anyone know if there’s a way to cut open the little reverse taillight portion without damaging the lens or anything important?
Old Aug 4, 2024 | 12:10 PM
STownSaint's Avatar
STownSaint
Sorry Op, don’t have an answer for you. But I think this has been a challenge for others with similar projects, and I’ve seen folks instead add a tint/film to the outside of that section (picking a shade that comes to a close enough match)
Old Aug 5, 2024 | 11:10 PM
Itagucci's Avatar
Itagucci
Could try using a hotknife to cut it open. I have seen people use that before for head lights and tail lights.
Old Aug 6, 2024 | 12:00 PM
rotarymike's Avatar
rotarymike
Moderator in Moderation
with sedans the reverse portion is a separate housing that you can get replacements for about $100 for the pair. I'd contemplated just keeping the outer lens and mounting studs and replacing the entire inner lens assembly with an LED COB board (flat LED chips). That's a thought. The reflective red IIRC is part of the plastic of the housing so even if you were to paint the inside black it would still be red-tinged (although that may look quite nice, if you can match it with the actual tail lights)
3fiftyzoom
Hawaii
Mar 2, 2019 03:28 AM
Ricio1991
Feb 13, 2016 12:13 AM
Mazaki
21
Jul 19, 2010 11:34 PM
nwryuber
Picture Share G Coupe
Mar 13, 2008 08:06 AM
