Seized engine after overheated
Aid. My G overheated when the coolant was low, so when I noticed, I stopped and waited a few seconds to check if it went down, but it didn't... So I turned it off and waited until the temperature went down, but as it went down. I was cranking without letting the engine start, it felt a little heavy and when the temperature got low, I started it after I put coolant in it and let it idle for about 5 minutes without any strange noise from the engine, no warning lights. engine, normal temperature, etc. The bad thing that happened is that when I was leaving the car turned out very well but after about 10 meters when I accelerated the car died, I waited another while and the car didn't want to start.
The next day I went with my friend to the car, we removed the serpentine belt, we tried to turn the engine and we realized that it was stuck so I immediately started searching since I had heard about how to unseize an engine, I saw some videos where they do it but They are left with fainting sounds. And my question is; It could be that just the piston rings of my engine got stuck and could I unsize the engine if I try? I’ll thanks any answer 👏🏽 please
chasem.37
Sep 30, 2023 01:33 PM
GiGGaplease
19
Jan 12, 2008 05:19 AM
