Sagging front bumper
Old Jan 8, 2022 | 07:59 PM
josev's Avatar
josev
I have a sagging bumper. I dont know if its the bumper or whats holding the bumper or if its the hood. From the side it looks normal so its probably the hood but I want to clarify.
Old Jan 9, 2022 | 08:56 AM
Rik R.'s Avatar
Rik R.
Your picture is pretty low-res so it's hard to say, but you need to check the panel gaps all around the hood and bumper. If you find uneven gaps around the hood, for example, that might point to it. If the bumper cover is pinching on the front fenders, as another example, it might mean someone tapped you and pushed your bumper cover back into the fenders and/or hood. But, basically, if the panel gaps on both pieces are regular, then I'd say it is your bumper cover since its plastic and can deform easier (and gradually) versus the hood.
Just go to a reputable collision repair center and have them give you an estimate... that will tell you what you're dealing with, from a professional, with no expense... then you can decide.
Good luck,
Rick
Old Jan 9, 2022 | 10:36 AM
dkmura's Avatar
dkmura
20 Year Member
The other possibility is there is damage to the lower valance that connects to the front bumper. If so, this would pull the entire structure down. If the valance (undertray) is missing, the front bumper can sag. Any damage to the undertray?
josev
Dec 14, 2021 06:12 AM
nonlinearedits
Aug 20, 2021 06:57 PM
Meijun Chen
May 24, 2017 11:10 PM
xtremeroller
Mar 8, 2014 01:11 PM
