Need help with wheel setup (I’m New here)
Old Dec 8, 2021 | 07:48 AM
EthansG37x's Avatar
EthansG37x
So just to make this easy cause I can’t seem to get a answer, will 18” VSR rims with 225/45R18 tires fit my 11 G37x
Old Dec 9, 2021 | 09:22 AM
Rik R.'s Avatar
Rik R.
Post Check this thread
I would suggest using this thread:
https://www.myg37.com/forums/wheels-...reference.html
It lists the wheel width and offsets, which is a requirement for a proper fit.
Good luck,
Rick
Old Dec 11, 2021 | 02:25 PM
Carboy37's Avatar
Carboy37
Do you have any wheel specifications? Generally that tire size should work, though the width can determine if your tires are not tall enough to keep your speedometer in check. For reference, I have a set of 245/45/18 on VMR wheels on sale that are 18x8 with an offset of 35 that fit beautifully and previously, I had G35 Sport Wheels that were 18x7.5 on 225/50/18 tires.
The site also has a Tire Rim calculator that can determine the difference between your current wheel and the wheel that you are considering.
Old Dec 11, 2021 | 07:38 PM
Ponyryd's Avatar
Ponyryd
To get an actual answer you will need the bolt pattern, bore, and offset.
Conboss
Sep 21, 2018 04:10 PM
wallstdevil
30
Feb 24, 2015 07:01 PM
