Rear Passenger window going down on its own
Old Jul 5, 2021 | 04:26 PM
hkbazzi's Avatar
hkbazzi
Unhappy Rear Passenger window going down on its own
Hi guys,
I don't know if anyone can help with this.
My car randomly pulls down the rear right passenger windows on its own. It did it once with the front left.
The car also has an android rear view mirror that started messing up (as if you got a 1000 fingers touching the screen)
The car won't hold a charge for more than 2 days it has to get jumped.
When the rear window went down it won't go back up. I replaced the front passenger switch with the rear one and it worked.
Things I am thinking:
- Bad alternator
- Bad battery
- Bad rear passenger window switch
- Bad master windows control unit (drivers side)
Did this happen to anyone here?
Thanks,
Bazz
Old Jul 5, 2021 | 05:13 PM
ILM-NC G37S's Avatar
ILM-NC G37S
For one, either you have a battery going bad or something is draining it dry. These cars exhibit very odd behaviors when the battery voltage gets very low. I would suggest you look into what is drawing your battery down before you troubleshoot further.
Otherwise, typically odd/ erratic window behavior almost always point to a bad switch.
czardini
Oct 3, 2022 03:54 PM
Kboyd
May 9, 2018 02:51 PM
txfan
Aug 4, 2014 09:40 PM
rodrich
Jan 8, 2014 11:05 PM
AuthorizedUser
Oct 22, 2013 01:30 PM
