Blinkers don’t work after car wash
Old Mar 3, 2021 | 04:13 PM
DylansG37's Avatar
DylansG37
It would not hurt. Just disconnect the battery and wait 10-15min. before disconnecting anything else. When you unplug the connectors look for signs or water, dirt, corrosion, etc. In the meantime you can investigate for any water intrusion (check floor pan, cabin filter, etc.).
If that does not work, I would suggest you have a qualified mechanic look at it before you blindly start replacing parts. Any competent mechanic (not necessarily the stealership)- preferably one with the Nissan CONSULT3 software- can fully and properly diagnose the issue.
You guys got my blinkers and wipers to work again. Thank you!!
so upon further inspecting the BCM I found water and ice on it. I unplugged the battery and unhooked the BCM, then I put a heater fan in it for about 2 days. Plugged everything back in today and everything works. Now I did feel dampness under the passenger rug and one of the drain tubes has condescension on it. I’ll do my research before I ask here though. Below are pics of the bcm and the tooth pick is pointing to where the ice was.
Old Mar 3, 2021 | 04:25 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Good news indeed...
There are tons of threads about water intrusion in that area. It is just a matter of investigating your own issue and going from there.
Is/was the cabin air filter wet/show signs of water damage?
Again, good news. Thanks for the update!
BTW: it is condensation, not condescension (blame the spell checker, lol).
Old Mar 3, 2021 | 04:29 PM
Selym's Avatar
Selym
I hope that didn't come from this forum!
Anyway, I'm glad you're making progress, and please keep us posted as to the source of the water ingress.
Old May 10, 2021 | 01:45 PM
DylansG37's Avatar
DylansG37
Update!
What’s up guys so I wanted to share an update and if anyone else has this problem they know how to fix it- I finally got around to actually fixing the water problem. Everyone was right and as suspected the sunroof passenger drain tube was clogged. I watched this video below and it was exactly what I needed.
I’ve never really worked on cars and this was about a 1 hour job for me- it’s simple, just time consuming. Below are pics before and after I cleaned the sunroof drain.
Just a quick thanks again to the guys that helped me diagnose this problem!
Before it was cleaned
After it was cleaned
Passenger side A panel removed as well as ac vent in order to access the tube.
Old May 10, 2021 | 06:36 PM
ILM-NC G37S
Thanks for the update. I am glad you got the issue resolved. I would recommend that every once in a while check the floor to make sure it is nice and dry. Otherwise, job well done!
Old Aug 3, 2021 | 01:40 PM
GTManiak's Avatar
GTManiak
My car ended up with the Exact same issue, except just after heavy rain. Thank you for making this post and thanks to all that knew/figured out the issue! I was able to get blinkera and wipers to work again!
UrBoiiJonny
Mar 3, 2021 06:44 PM
mathmusicmikey
Apr 14, 2019 06:50 PM
Matty_baby
Picture Share G Coupe
21
Feb 6, 2019 03:09 AM
Hiram Abiff
Jun 5, 2010 01:55 AM
