Transmission Fluid Help!
Old Nov 6, 2020 | 06:40 PM
hudzpud's Avatar
hudzpud
Hello fellow g37 owners, I recently had my engine service soon light come on. So I went to autozone to get a error code; P0710 Transmission Fluid Temperature Sensor A Circuit. I was wondering if any of yall have experience this issue and give me some insight as to what the problem may be. I hope its just a loose sensor as I did recently do a oil change but I jacked it on one side in a very weird angle. My car is a 2013 g37 at 85,000 miles. Thanks in advance!
Best Regards,
Tien Le
Old Nov 6, 2020 | 11:31 PM
dkmura's Avatar
dkmura
20 Year Member
This isn't a common problem with the G37. Depending on where you jacked on the frame, you may have damaged a sensor. Check the FSM for details on where the tranny temp sensor is located, or take it to a garage.
Old Nov 7, 2020 | 11:36 AM
hudzpud's Avatar
hudzpud
Thanks for the reply! I probably take it to my local shop, just thought maybe this could be a easy self fix if this was a common occurrence. Again thanks for the advice. I also found a TSB for the error.
15jeffreyr
13
Sep 21, 2021 02:56 PM
Malik Scriven
May 3, 2020 11:56 AM
conroy
General Tech Questions
Dec 18, 2017 10:14 AM
Victory
Aug 22, 2016 05:47 PM
bythabay
Jan 4, 2012 01:20 PM
