Hi,
I have an issue with driver seat and mirrors, currently not working:
- driver side seat buttons (only lumbar support is working)
- mirrors joystick
- seat memory buttons
- seat not moving back and steering wheel not lifting up after door opened (also the menu items are lost from the console)
There are no any error codes, all fuses are ok, is it an ecu problem?
There is a module under the driver seat which controls all this. It sounds like yours may be messed up or failed. First I would check all the wiring / plugs on that. If not, may want to replace that unit.
Actually, if it's mirrors too it's more likely to be the black box called "automatic drive positioner control unit" located on the left side of the center dash above the accelerator pedal. My 2013 sedan FSM shows fuse #10 (in-cabin fusebox near the driver's left leg) is the main power source. But interestingly it also shows a "circuit breaker" limiting power to that unit and located around the same area as the processor - behind the trim near the driver's right knee. That breaker may be self resetting so no idea what the point of it is - maybe like a travel limiter?
thank you 13_SkylineSedan for diagram, I also tested with used ADP unit but no success, so I must next check this circuit breaker but I cant find its location, real photo or part number, is anyone have much detailed info about it?
You see on the diagram the breaker's connector is marked "M62". Attached is the main wiring harness illustration from 2013 FSM showing the location. Probably looks like a relay or something?
Hi,
- mirrors joystick
Hey, sorry to drag up an old thread but how did you finally resolve this? I'm having the same exact problem. Fuses test good. Steering wheel still tilts but everything else (mirrors, seat controls, memory buttons are all dead)
checked M62 circuit breaker, its ok, looks like a bcm issue
I have the same problem, I’ve checked all fuses, and replaced the power seat module, how did you test the circuit breaker to see if that was the issue?
Hey, how are you doing , I’m actually having the same problem one day you had , did you ever got it fixed and and what was the problem ? If you can please let me know I would really appreciate it.
Did you ever figure this out bro? I’m having the same issue.
