N/A hp
Old Jun 5, 2020 | 05:52 PM
Trinidad Jimrel's Avatar
Trinidad Jimrel
N/A hp
How much hp can you get out of stock engine naturally
Old Jun 6, 2020 | 12:35 PM
jfridge92's Avatar
jfridge92
With full bolt-ons (intake, test pipes, full catback exhaust, headers, and tune) most usually see around 320-330WHP, and that is typically with 3" intakes.
If you go further and upgrade injectors, run E85, ported upper and lower intake manifolds, etc, you may be able to get closer to 340 WHP but that is on the high side. 320WHP is a more "typical" number on a stock motor with no boost or nitrous.
Old Jun 6, 2020 | 02:12 PM
Birdie's Avatar
Birdie
I would say somewhere between 325 to 375 depending on what kind of fuel you are using
Old Jun 8, 2020 | 09:52 AM
RMB5190's Avatar
RMB5190
A lot depends on drive line. RWD will see higher numbers than an X due to the AWD sapping; MT v. AT also is a factor. If you do a typical 2.5'' intake, test pipes/HFC, and exhaust, a tune will put you around 310-320whp and 250-260wtq on a 93 oct. tune. Numbers aren't world beating but it's going to be a very quick DD at that point.
Anything more than that becomes a question of $ per HP. Headers, 3'' intakes, ported lower IM / upper IM and throttle body upgrades aren't cheap. At that point, going FI should be considered.
awightguy
May 19, 2013 07:48 PM
GWong8
12
Apr 12, 2011 08:36 PM
dainjarouz
General Tech Questions
22
May 10, 2010 11:32 PM
mcgrible
Oct 25, 2009 12:45 AM
