My 2009 G37 sedan won’t start
Old May 21, 2020 | 03:24 PM
Im_drk's Avatar
Im_drk
I have tried a different battery with charge and was still making this noise. I’m assuming I need to replace the starter does anyone know how I fix this?
here’s the video:
G37 Startup Video
Old May 21, 2020 | 10:18 PM
Broken_2008_G37's Avatar
Broken_2008_G37
bad starter? borrow someone's code reader and see what it says.
Old May 21, 2020 | 10:54 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by Im_drk
II’m assuming I need to replace the starter does anyone know how I fix this?
here’s the video:
G37 Startup Video
I hate to say it but based on that video clip your starter is likely done. The pinion gear is not fully extending which prevents it from making full contact with the teeth on the flywheel ring gear. That sound is the pinion grinding against the ring. This could be a result of a worn out solenoid, dried out grease, or just age.
Technically, replacing a starter is a relatively easy repair. However with these cars, due to the tight clearance, it takes some clever maneuvering and A LOT of patience to get it out.
Good luck...
Old May 22, 2020 | 12:15 AM
Im_drk's Avatar
Im_drk
Fixed
Went to autozone right after and bought another battery and it cranked and started with no problems. Not too sure why the hiccup was.
Old May 22, 2020 | 08:29 AM
ILM-NC G37S
Strange. But at least you are up and running.
peter60
Apr 1, 2020 02:16 AM
Rick in NC
Feb 18, 2016 06:22 PM
RQ1986
NorthEast
Feb 11, 2015 04:34 PM
tifosi
Jul 10, 2013 09:06 PM
SilverTL05
Apr 1, 2009 10:34 PM
