Help ?? G37 Sedan
Old Jan 29, 2018 | 12:21 PM
Sparrow Greg's Avatar
Sparrow Greg
Help ?? G37 Sedan
Hey guys I own a 2011 G37 sedan and yesterday it rained like crazy and today when I got in the rear driver carpet was completely wet, the passenger was as well but very little compared to driver side, also driver front and passenger front carpet is wet as well, I did notice the passenger front plastics by where your right foot would usually be placed is wet maybe from the ac? I have no idea what can be causing this and would like to know if this has happened to anyone else ??
Old Jan 29, 2018 | 12:46 PM
GeezerB's Avatar
GeezerB
Were you driving car in rain or was it just parked?
Old Jan 29, 2018 | 01:15 PM
Sparrow Greg
The car was parked
Old Jan 29, 2018 | 02:03 PM
Michael_in_DE's Avatar
Michael_in_DE
I believe the sunroof drains are the usual culprits of the water in the interior, although it usually ends up in the passenger footwell I believe? Is it usually parked outside maybe under a tree occasionally?
Old Jan 29, 2018 | 02:09 PM
RMB5190's Avatar
RMB5190
^Here's your most likely cause. Take a little bottle of water and let it run into your drain holes in the sun roof. It should run out the bottom of the car. If it doesn't, there's your issue.
Old Jan 29, 2018 | 04:21 PM
Sparrow Greg
Nope it’s usually parked on my driveway with no trees around it, I am going to do the water bottle test and see what happens I’ll let you guys updated, thanks for the information. And yes there’s water on the passenger footwell as well
Old Jan 29, 2018 | 04:37 PM
slartibartfast's Avatar
slartibartfast
The drains run under the A-pillar trim and out through the firewall. Infinit went cheap on the rubner piece that forms the grommet and it can't handle the engine compartment environment. It's not cheap to have the dealer fix the problem.
Infiniti will remove the interior to dry it but they charge a pretty penny to do so. My dealer monkey scratched paint on both door frames and dealer wouldn't pay to fix the damage. Also damaged was the left lower door finisher which they did replace. Dash wasn't reinstalled correctly and I had go back to have that fixed. I have not been back to that dealer.
Old Jan 30, 2018 | 01:03 PM
Sparrow Greg
Update... it hasn’t rained at all and the driver side front carpet is wet, could it be ac?
Old Jan 30, 2018 | 03:22 PM
slartibartfast
Maybe.
Is there an antifreeze smell? That would indicate a leaking heater core.
Old Jan 31, 2018 | 06:42 AM
Sparrow Greg
Nope antifreeze is full and hasn’t rained at all, passenger front carpet is wet as well, at this point I think it’s the ac drain is clogged
MagnanPI
Jun 24, 2016 06:29 PM
Rickyay
Jun 23, 2016 08:37 AM
TD74
Buying & Leasing
Feb 13, 2010 04:38 AM
Uho001
Dec 18, 2009 08:49 PM
