Help!!!
Old Jan 25, 2018 | 09:30 PM
Justin2528's Avatar
Justin2528
Help!!!
So I am removing the front bumper and to do so you need to take off 2 bolts in the wheel well under the fender liner on each side. Well one of the harder ones to get to is stripped! How can I get this off? I've tried to hammer on a 9mm (the bolt is a 10mm) but there is not enough space to do it. What do I do?
Old Jan 25, 2018 | 09:39 PM
RMB5190's Avatar
RMB5190
Spray it with some PB blaster and see if you can get a pair of channel locks on it would be my recommendation.
Old Jan 25, 2018 | 09:44 PM
Justin2528's Avatar
Justin2528
There isn't enough space to do that
Old Jan 25, 2018 | 09:53 PM
RMB5190's Avatar
RMB5190
Trying to recall when I removed mine. Think I man-handled my well liner out of the way. You have the wheel turned all the way 'in' on the troublesome side correct? Might need to go from the bottom up, remove skid plate and see if you can gain access that way.
Old Jan 25, 2018 | 09:59 PM
Justin2528's Avatar
Justin2528
I may go buy a bolt extractor socket.
Old Jan 25, 2018 | 11:00 PM
slartibartfast's Avatar
slartibartfast
Sorry, gotta say it. I saw the thread title and immediately heard the Beatles in my head.
Old Jan 26, 2018 | 07:30 AM
RMB5190's Avatar
RMB5190
Or you could go that route. I picked up the $30-40 one from sears and it payed itself off in the first use.
Old Jan 26, 2018 | 07:33 AM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
take your wheel off, peel the fender lining back.....wahhlaaaa plenty of room to access the bolt.
Old Jan 26, 2018 | 01:17 PM
slartibartfast
...wahhlaaaa...
DFS meant "et voilà". Gotta add that "et" (and) in front.
Sure wish I knew how to access the extended character set on this iPad. I had to Google the term, then copy-and-paste.
Old Jan 26, 2018 | 04:17 PM
kroy's Avatar
kroy
OP needs somebody.
Old Jan 26, 2018 | 06:28 PM
slartibartfast
I'm lauging so hard cat is giving me a WTF look.
Uho001
Dec 18, 2009 08:49 PM
jnguyen
Oct 20, 2008 11:26 PM
