How do you feel about the G's gas mileage?
#47
Happy New Year guys. The VQ37 is an older engine that does not get very good gas mileage and decent performance, but at least it is safe to say that this engine is bullet proof and very reliable. I sometimes think that I should have just gotten a V8 car that has better performance with the same running cost as the G, but this car is hard to get rid off. The driving experience is a 10 out of 10 and that for me over powers the car's flaws. Sad to see though that Nissan Infiniti is facing out the VQ37. I honestly hope they do not do this because it is still a great engine.
#48
Wow that is the first time I ever heard a G getting above 27 mpg. Are you using the G's computer or do the old division by hand calculation? I also live in CA and struggle to get above 24 lol!
#49
#50
I look at the Gs computer to see what it'll give me but I also do a manual calculation when I fill up to get more accurate numbers because the computer likes to lie. The last time I went to cali though I never got past 27mpg.
#51
Never heard of such issue. What exactly happened and how much money did it cost to repair? I always read VQs to be one of the most reliable motors out there. I mean it is used in a lot of Nissan Products. I hope you sorted things out and all is well.
#52
Haha the computer loves to lie. I also do manual calculations but I look at the computer readings to see if my mileage increases or decreases in my trips. VQs are really thirsty V6 beasts. A buddy of mine has a Nissan frontier. I believe it is a 4.0 VQ V6 and it drinks gas like a Titan. He told me he should have gotten a Titan instead because it had more horse power and torque and uses about the same amount of fuel lol.
#53
The rear timing cover gaskets would fail and cause the engine to lose oil pressure. Car runs into limp mode and you'll get a check engine light.
It's a very labor intensive task to attempt to fix yourself, especially if you don't have the time, tools or knowledge to do it.
I've heard dealerships charge somewhere around the ~$2,500++ for this repair.
The entire front end of the car must be removed. As in head lights, bumper, radiator, condenser, bumper support. EVERYTHING. Dealers charge 12-18 hours labor I think.
This hasn't happened to me yet, but just knowing that my car is a 2011 is enough to haunt me. I know that it's possible my car will have this issue down the road...
#54
Pretty sure 2011 was the last model year with that problem, and it was specific to the VQ37HR. Starting 2012, Nissan switched to a metal gasket for the rear timing cover. But yeah... owning a G37 before 2012 is a gamble as to whether or not the timing gasket will hold up over time (no pun).
Usually it's Newt going all Chicken Little on this topic.
#55
#56
^ even on pre-2012 VQ37HR's, the timing cover gasket failure issue is not a given. far from it. when my dealer did my repair under warranty in ~2015/16, the service manager said i was only the 2nd or 3rd such warranty claim in their history.
is it a known issue with the VQ37? sure. is it common? no. is it over-reported on this forum? you bet. just like the CSC issue and several others...still, it's always good to be aware and have knowledge on the matter in case you are faced with the problem.
The following 2 users liked this post by canucklehead:
Lego_Maniac (01-03-2018),
Rochester (01-03-2018)
#57
However, just like you with the timing gasket, I was one of those poor slobs who's CSC blew without even 20k miles on the car, so my head says don't worry, while my gut scares me into thinking I'm a sitting duck.
But you're still right. Absolutely right. Statistical anomalies.
#58
As for the thread...Low key I'm a little disappointed that our MPG is v8 mustang and Camaro territory, with 100 less HP. I struggle to get anything about 25 MPG on the freeway only, which is normal I guess when I have a G37S. But jeez, it's very painful to see my car revving at 2700 RPM going 75 in 7th gear, when a Nissan altima does it at a much lower sub 2000 rpm. More so, its extremely annoying when I shift from 6th to 7th and the ratio difference is barely anything. Quite literally, the 6th and 7th gear can just be combined to be one gear....there's no need for the 7th. Nissan should have really made that 7th gear a real over drive gear that brings the RPM's down at highway speed. Absolutely no reason to be wasting gas like that...
