Tomei exhaust help
Old Nov 28, 2017 | 02:14 PM
Arnel's Avatar
Arnel
Smile Tomei exhaust help
So I have a 2013 Infiniti G37x sedan, and want a single cut Tomei exhaust. How do I go about finding the right one and installing? Links would be appreciated ☺️
Old Nov 28, 2017 | 04:51 PM
stiizy's Avatar
stiizy
https://www.myg37.com/forums/search....rchid=12514824
Old Nov 28, 2017 | 06:44 PM
PNW_IPL's Avatar
PNW_IPL
you dont.
tomei makes an exhaust for the 370z. They do not make one for the g37. I run the tomei on my coupe with and extension pipe. I have no idea if itll fit the sedan. Only way to find out is to try and custom fit it.
Old Nov 28, 2017 | 07:15 PM
Arnel's Avatar
Arnel
Originally Posted by PNW_IPL
you dont.
awh man, I was hoping it would. I’ve seen it on the coupe versions only. Was hoping somebody on here had it on he sedan.
Old Nov 28, 2017 | 08:04 PM
MaQG37's Avatar
MaQG37
There are a few that have it on the sedan.You will need to extend the exhaust about 16''. You can choose to buy a Z1 extension and have a exhaust shop extend it out even more or you can just have the exhaust shop take piping with 2 flanges.
https://www.z1motorsports.com/exhaus...pe-p-9596.html
However, I don't think the tomei Y pipe will fit your transfer case being AWD. You may need to do something different with the Y pipe and run the tomei after that Y pipe.
Old Nov 29, 2017 | 12:07 AM
ezbme's Avatar
ezbme
I have seen the mufflers sold by themselves. Perhaps you just get a muffler shop to run a pipe to the muffler. The muffler is around 350, then you can get a X or H pipe for 250 on up. I have thought about getting two of the Tomei Mufflers and getting the weight down a bit. I figure if one is loud, perhaps two will be good.
I am about efficiency, would rather not let people know I am pushing it. I have heard a lot of cars with loud exhausts with cars going slowly. I would have the opposite as much as that is possible.
