blue tooth
Old Oct 5, 2017 | 02:19 PM
Ac Molina's Avatar
Ac Molina
blue tooth
have 2013 g37, not the navigation system, is there any way to connect my phone galaxy s8 to the car?
Old Oct 7, 2017 | 08:10 AM
JustROLLIN's Avatar
JustROLLIN
A search on this topic will yield many results. That said, I use the following product. Its quite seamless, including the steering wheel controls. However, artist info does not display.
https://www.viseeousa.com/products/v...-usb-connector
Old Oct 12, 2017 | 02:02 PM
Ac Molina's Avatar
Ac Molina
Thanks, but have Galaxy S8, says only works with iPhone, iPad or iPod
Old Oct 12, 2017 | 04:25 PM
13_SkylineSedan's Avatar
13_SkylineSedan
from the Infiniti website:
Good news! Your Samsung and G Sedan are compatible. Go ahead and connect them.
2013 G Sedan, No Navigation System, ATT (my guess), Samsung Galaxy S8
Bluetooth for phone calls...
Switch on you phone's Bluetooth.
Press the "dial" button on the steering wheel
as prompted say "connect phone"
follow further instructions...
If you want to use the phone to play music you'll need to plug it into the USB jack in the center console. (Sometimes you might need to start the phone playing something and then plug it in for the car to recognize it.)
Old Oct 14, 2017 | 04:09 PM
slartibartfast's Avatar
slartibartfast
Does playing from phone eliminate the thousand file limit?
Old Oct 15, 2017 | 12:31 PM
13_SkylineSedan
As far as I know using the USB port as an "audio in" should allow you to play anything you have on your phone. You may not be able to access all the info on your car's screen ... but any music, podcast, audiobook, etc. that your phone can play should be able to pass audio through your sound system via that USB jack.
