Drivers side lock trim cover
Old Sep 10, 2017 | 10:07 PM
zois's Avatar
zois
Hi all,
Need some assistance finding this part. On my 04 coupe, they sold the drivers side lock trim cover delete that was paint to match. I'm now looking for that same part for my 2013 sedan moonlight white (QAA). I been searching web high and low with no luck but I figured someone on this forum has to know if I can still get that part. At one point infiniti offered this piece as a OEM accessory back in 2004. Thanks for everyone's time on this.
Old Sep 12, 2017 | 10:01 AM
Baby Jumpman's Avatar
Baby Jumpman
80646ju60a
Double check with the dealership, but that should be it. Also I'd order from somewhere online, since it'll be cheaper.
Old Sep 12, 2017 | 08:44 PM
zois's Avatar
zois
Thanks for the assistance. That part number looks like its for the regular trim cover with keyhole. I'm looking to cap it so it doesn't look as ugly.
Old Sep 12, 2017 | 09:21 PM
Baby Jumpman
You'll get both sides when you order, at least I did when I got them from discountinfinitiparts.com
If your battery ever dies with your doors locked you'll be screwed. Unless your windows are open.
Old Sep 12, 2017 | 09:29 PM
zois's Avatar
zois
I appreciate that. I'm on the website now and it looks like what I'm looking for. So with my coupe I was able to separate the blank that came with it and simply removed the old and capped it. When my battery did die, I was able to pop the cover exposing the lock cylinder. The idea is not to remove the lock cylinder.
Old Sep 13, 2017 | 09:01 PM
saywat?'s Avatar
saywat?
lexus IS is like this. theres a cap and when drivers need to use the key hole theres a little hole to pop the cap off lol
