Stripped front crossbar bolts
Old Aug 24, 2017 | 03:31 PM
monty2003's Avatar
monty2003
I forgot that the torque listed in the FSM is Newton Meters (NM) and the second value in the brackets is Ft. Lbs. I torqued the two outer mount bolts (attempted to anyhow) on the front crossbar (AWD) to 63 Ft Lbs and they kept turning. Turns out I should have torqued to 46.
Anyone have any knowledge about what these bolts screw into? Any likelihood that I can use a size larger bolt size and retap the hole?
Here's the snap from the FSM showing the bolts I messed up.
Brian
Old Aug 24, 2017 | 04:55 PM
It's a pain in the azz, but your best option is probably to drill it out and use an EZ-Lok insert.
Old Aug 24, 2017 | 05:53 PM
AARONHL's Avatar
AARONHL
drill it and re tap it a lil bigger
Old Aug 25, 2017 | 09:51 PM
monty2003's Avatar
monty2003
Looked in my tap kit and had an M11x1.5 but could not find an M11 bolt anywhere.
Found M10 x 1.25 thread repair kit at Napa for $65 bucks (the right bolt). Amazon had the kit for $29 but I didn't want to wait a few days.
Found M10 x 1.5 thread repair kit at advance auto for $23 and bought it.
Drilled the old threads out with a 13/32 bit, tapped both holes it with the provided tap, inserted the helicoils, broke off the tabs, and torqued the new M10 x 1.5 bolts down to 40 ft-lbs. Was surprised at how easily the old threads came out and how easy it was to tap. It was soft metal.
All is good.
The next size up bolt that I could find at the hardware store was M12x1.5 and that's a big bolt! Instead I tried to stay as close as possible to the original size.
First time using a helicoil and it was easier than I thought. The EZ LOK inserts are nice but they are thick which requires a big hole so I went with the coils.
Thanks guys.
Brian
Old Aug 25, 2017 | 10:00 PM
AARONHL's Avatar
AARONHL
Ya bro I forgot to say heli coil those things things are awesome
