Power Steering Fuild part #?
Do you know what is the OEM power steering fluid that dealer put in my car? It's 13' G37x.
I don't want mix with different fluid like Dexron III. Link me here or give me part number so that I can order one online if possible. I've found one online but not sure if this is the one that dealer put in. HERE
Thanks for helping me out.
i believe it's Nissan PS fluid, may even be some other labeled fluid like ATF. i did mine a couple years ago and went to the Nissan dealer for the fluid. just can't recall if it is labeled ATF or PS fluid. regardless, it is a Nissan bottle and is considered the OEM fluid.
wow almost $8 for 12oz of nissan p/s fluid which is just dexron3. its cheaper to get a quart of dexron3 for $8. btw 16oz to 1 pint. and 2 pints to 1 quart. in addition nissan like other auto manufacturers do not make fluids, its all made by some major refiner like exxon mobil, bp, conoco philips, and so forth. skip the nissan p/s fluid and get a bottle of mobil or valvoline dexron3 its the same thing.
I bought 2 quarts of redline dex 6 fluid when i did mine. Did a evac/refill of the reservoir about 6 or 7 times. In between each refill, the car was started, and steering wheel turned lock to lock several times slowly. Front end was jacked up so tires were off the ground. Good enough for me.
